Old 04-17-2015, 08:10 PM   #21
Bilcin's Avatar
Originally Posted by fonzie View Post
Looks like the valves are in summer position. The one by the cold water line is a three way valve which looks is set for water to flow to water heater. Red line is hot water line and valve looks like it is open, so water should flow properly. Turn water pump on and open only hot water faucet and wait until water comes out steady for one minutes and that should be it. To make sure water hater is full you can also open water heater relief valve to make sure tank is full.
PS: I did say to look underneath bed.....
That worked! was not letting the hot water run long enough to empty out all of the air. now the pump shuts off and only goes on when I call for a water hot or cold.
Fonzie, you help me out with my weight distributing hitch problem and now with this thank you. I owe you a big beer around a campfire! and also I want to thank the other posters for their help also really do appreciate it.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 04-17-2015, 08:18 PM   #22
fonzie's Avatar
Glad it's all working for you.....
Fonzie
Old 04-17-2015, 08:37 PM   #23
B and B's Avatar
Good you found them and everything is working. Remember to open the low point drains and flush them as well. There is antifreeze in them as well, otherwise mixing with some chlorinated water the water will stink really bad.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-17-2015, 08:55 PM   #24
Bilcin's Avatar
Thanks !!!!!!!!! On the way out to my driveway to do that now! Didn't realize that had to be done! This forum is AWSOME!!!
Philadelphia PA
Old 04-18-2015, 05:17 PM   #25
With the HW tank is located at the front maybe the factory did not install the necessary piping to bypass it or they have run the piping to some other part or panel of the trailer. You can still fill the tank most of the way full by manual procedure--Open the HOT Water faucets so as to relieve the back pressure on tank and remove the pressure valve near the top part of tank (It's the little Do Hicky with a leaver attached) and use a water hose to fill most of the tank. Turn on switch for your pump and water should flow from the removed pressure valve hole within a short time period. Stop pump and reinstall the pressure valve with pipe seal on the threads. Close faucets and lines should pressurize with use of pump when started again.
saltyman is offline   Reply With Quote
Old 04-20-2015, 02:57 PM   #26
Bilcin's Avatar
Thanks for the reply, I found the access panel with the help of Fonzie, previous page. All is working as should be!
Philadelphia PA
Old 04-21-2015, 10:29 AM   #27
Also be sure the hot water heater plug is in tightly. If wh plug is not in and bypass is to summer position the pressure to stop the pump will not build up.
RetCityMan
CityMan is offline   Reply With Quote
Old 04-24-2015, 08:36 AM   #28
Bilcin's Avatar
RetCityMan
Where is the WH plug located at, for future reference?
Philadelphia PA
Old 04-24-2015, 08:51 AM   #29
If by pass valve is in correct position make sure WH plug is in the unit and tight.
RetCityMan
Old 04-24-2015, 09:49 AM   #30
Bilcin's Avatar
RetCityMan
When you say "WH plug", are you referring to the bolt/ annode rod?
Philadelphia PA
pump, water, water pump
