Old 04-24-2015, 10:03 AM   #31
RSchleder's Avatar
I didn't make the post, however, I'm sure your correct. Plug = water heater anode.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 04-24-2015, 10:09 AM   #32
Bilcin's Avatar
Thank you, that is the only thing I think of as a plug.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 04-24-2015, 05:57 PM   #33
That's correct, there's nothing else.
SkipnTerri is offline   Reply With Quote
Old 04-24-2015, 06:12 PM   #34
It looks like you have the different valves figured out so try this. I had this problem once. The fresh water tank pipe that feed the pump probably has an air bubble in it. fill the fresh water tank and then put the hose in the fill port and put something around the hose to keep water from flowing back. What you are attempting is to pup pressure on the fresh water tank to force the air bubble out. Any excess water will come out of the vent pipe so look out so you don't get hit with that water. It does not take much to force the bubble out. If this does not work, make sure there is a path for water between the tank and pump. Good luck
sdfarmer is offline   Reply With Quote
Old 04-24-2015, 09:06 PM   #35
Bilcin's Avatar
Thanks for the tip! Will keep it in mind if this happens again. Have a nice weekend!
Philadelphia PA
Old 04-25-2015, 06:01 AM   #36
Wish i seen this sooner. Where in philly are you?
2017 Freedom Express 271bl
2013 Silverado Z71
TimNJTA is offline   Reply With Quote
Old 04-25-2015, 11:51 AM   #37
Bilcin's Avatar
Northeast, Rhawn and Roosevelt Boulevard. Are you from Philly?
Philadelphia PA
Old 04-25-2015, 02:20 PM   #38
Bilcin's Avatar
Never mind, I read you Bio and know you are not from Philly.
Philadelphia PA
pump, water, water pump
