Old 04-09-2013, 02:16 PM   #1
Water pump wont shut off and no mostly air coming from faucet
Hi all my name is Tony,
New to the forum. I just un-winterized the TT today. All was going well until I got to the pump step. I filled the tank with water and turned on the pump. It ran and ran and ran and will still run if I turn it back on. I filled the hot water tank with water. still runs. all faucets are off. I dont see any visible leaks
this is a 2012 Shasta Revere 26TQBQ...
The dealer winterized it and I didnt want to spend $125 to basically drain the anti freeze and open a few valves.
I am not sure what to look for since the pump does run and I dont see leaks. Is there a step I missed?
thank in advance for any responses.
tpetillo66 is offline   Reply With Quote
Old 04-09-2013, 02:29 PM   #2
mTn_biKer65's Avatar
You say you've checked for leaks with the pump running was that inside and out? If the city water check valve isn't seated correctly water will spew from this hole with the pump on. Also, have you looked underneath to verify the low-point drain isn't spewing water when the pumps on? You say the hot water tank was filled, was this dome by the pump from the fresh water tank? And you say it's filled did you confirm this at the check valve on the hot water tank?
There's possibly a shut-off between the fresh water tank and the pump that might be turned off but if the water heater's full then that's unlikely.
Paul
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 04-09-2013, 02:38 PM   #3
jlbreaux's Avatar
Sounds like you are out of water. Your tank may be "water logged", or your pump may not be priming. We went self-contained camping a few weeks, so like you I filled up the freshwater tank.....so I thought. We had water the first night, the next morning I noticed my pump was running and mostly air was coming from the faucet. We were out of water, it seems the fill hose was in a position (about 4"'s higher than the fill cap) to allow a few gallons of water in but that was it. Once I noticed I pulled my filler neck out and cut off a good 6 inches, we transferred 2/3’s of water from my friends tank to mine with no problem.
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 04-09-2013, 02:40 PM   #4
TURBS's Avatar
theres most likely air in the system .... most likely in the water heater .
did you turn the water heater by pass valves ?
did you bleed the air out of the hot water tank ?
turbs
Old 04-09-2013, 02:55 PM   #5
Herk7769's Avatar
My money is on you "ran out of water" in the fresh tank.
While it is also possible that the pressure cut off switch or the one way check valve in the water pump have failed (both would let the pump run), I think you are sucking air.
HAM CALLSIGN - KC3FFW
Old 04-09-2013, 02:59 PM   #6
Wow, I have to say what quick responses. I could hear the hot water tank filling and I released the pressure valve to get al the air out until water was coming out.
I dont have any other valves on this thing unless they are hidden beneath the underside cover. However that is unlikely considering how tough it is to get to the cover to remove it even for a small valve. I dont see any access points on it other than where the gas lines go in and out and those are sealed up.
There is no water coming out anywhere on any part of the TT. I just tried again and it seems to be sending some water but its sputtering.
I just filled it and it took a good amount of time to fill and the light indicator says I am on a full tank. One thing I did notice is that it says full but the green light is blinking when I hit the test levels button...
Could this be telling me there is a problem. I am going through all the books it came with concerning plumbing but they are very basic books.
When I take the strainer cap off, while the pump is running I dont hear any water or see any water coming though. How fool proof are these cheap plastic valves? Could the open close valved from the tank be stuck? or onlyh partially open?
Old 04-09-2013, 03:01 PM   #7
Oh yeah. I also took the end of the valve off that goes into the pump and blew into it. It seemed to be free flowing.
Old 04-09-2013, 03:14 PM   #8
OK, so here is what I did next, after seeing many of you tell me its out of water, I went back and filled the tank more. I slowed the water pressure and it took quite a bit more, maybe another 4 minutes of filling. I think went inside hit the switch and it worked. The pumped filled with water and stopped. Water now flows from the faucets. I think what is contributing is a leak though. Now that there is constant pressure on the fitting leading into the pump its leaking. So now I am draining that until I can get a new one. Perhaps not being completely full with this leak it was sucking in too much air and could not get enough pressure from the tank to get the water flowing???
Thanks all for you posts, I really appreciate all the help. Hopefully this will help others.
Old 04-09-2013, 03:18 PM   #9
Herk7769's Avatar
If the screened bowl is dry you are sucking air on the pump.
Make sure all the fittings are tight and the winterization bypass is connected to the fresh water tank instead of the antifreeze hose.
The check valve and pressure switch are INTERNAL to the water pump.
If this is your problem, SOME pumps can be rebuilt, but most need to be replaced.
ID:	27508   Click image for larger version
Name:	Shurflo Pump IPB.jpg
ID:	27510   Click image for larger version
File Type: pdf Classic Pump - pds-2088-422-144_444_.pdf (192.4 KB, 18 views)
Old 04-09-2013, 03:32 PM   #10
Mountainmanbob's Avatar
after our RVs have set a while with the water off
when turning back on
good idea to open slightly a couple of facet's
so as to let the air out
then once all air is out turn facet's off
pump should stop running in very short time
plus
this way we know for sure that water is being delivered
Mountainman
Mountainmanbob is offline   Reply With Quote
