Old 03-29-2018, 06:00 PM   #1
Water pump won't stay primed
Hi everyone, my trailer is a almost 5 years old. Just pulled it out two weeks ago for our earliest camping trip ever. Last weekend right before we left, I waited until the last moment to prime the water pump, because it's still pretty cold here. Once I got it going, everything seemed ok, but it didn't sound normal. It takes longer to recover each time it's used. It seemed ok otherwise. Well, first time we went to use it when we arrived at our destination, it wasn't primed. That's not normal. It gets primed, and stays pressurized. It's not leaking on the pressurized side, because I don't hear it running when water isn't used. But after 30 minutes of no water use, it starts to lose its prime, and it takes a good 15 seconds to recover. First thing in the morning takes even longer.
I've looked at connections, removed strainer and checked. Everything is tight. Checked the bypass valve, too. Water flows great once it's primed, but the pump just won't stay primed. Is this the pump going bad?
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 03-29-2018, 10:01 PM   #2
I may have solved my own problem. Being the tinkerer I am, I just took the pump head apart. I didn't really see anything wrong, so I cleaned it up. Especially an o-ring up top that looked a tad gunky. Once I got it hooked back up, it sounds like a new pump. Hoping it fixes the prime loss, too.
Old 03-30-2018, 09:21 AM   #3
I spoke too soon. I let it sit all night, came back out and while there was still lots of pressure, it took a good 15 seconds for the pump to prime again. Not sure what to do about that. Pump certainly sounds better and pressurizes faster though.
Old 03-30-2018, 09:27 AM   #4
SeaDog's Avatar
when you say prime you are you meaning come up to pressure and shut off? If it wasn't priming you would have no water pressure. Its not unusual for a pump to loose a little pressure while sitting because of the internal check valve leaking back. As long as its not cycling on and off. A five year old pump may have to run a little longer then when new.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-30-2018, 09:28 AM   #5
marinerjoe's Avatar
Sounds like it's time to look at the suction side of your setup, starting with the pump itself, and working towards the water tank. Including the diverter valve that allows you to choose between the winterizing connection or the storage tank itself.. Make sure all the connections are tight. Other than that, not sure what else you can do.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 03-30-2018, 09:39 AM   #6
No, the inlet side is allowing water to drop back into the tank, so after sitting for awhile it takes the pump 15 seconds or so to get pressure to build properly. It's as if I went to the pump, disconnected the inlet line, let the water flow back to the tank, reconnected and turned on the pump. Takes 15 seconds or so to pick up from the fresh tank again.
Old 03-30-2018, 09:49 AM   #7
Scoundrel
HangDiver's Avatar
Apparently the check valve on the pump is not seating properly.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-30-2018, 09:51 AM   #8
Thankfully mine is SUPER simple. The tank inlet, vent tube, and tube going to the pump are all right next to the water pump where it goes into the tank. So the pickup line is only about 18" long above the floor, and does straight down into the tank. It comes out of the tank, goes into the diverter valve, then from there it's about 3" of hose to the elbow right before it goes into the pump. So there's 3 crimp connectors there. Then on the T side of the diverter is about an 18" section of hose with a cap on the end for winterizing. Honestly not sure where it could be sucking any air from. I guess I could go back and re-crimp all those connectors, or maybe swap them out for screw-type hose clamps.
Old 03-30-2018, 09:54 AM   #9
marinerjoe's Avatar
That may not be the case if he's getting a decent shot of water, and then it drops off until the prime builds back up again.
Joe
Old 03-30-2018, 09:55 AM   #10
Flybob's Avatar
Recheck the winterizing valve. Even a small leak will allow air to enter and the prime will be lost.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-30-2018, 09:56 AM   #11
That is EXACTLY what is happening. Pressure bursts out, drops, then 15 seconds to build again, back to normal.
Old 03-30-2018, 09:58 AM   #12
Will do. Maybe I'll just pull the valve off completely and try to get rid of as many connectors as possible in order to test.
Old 03-30-2018, 01:04 PM   #13
Just checking to confirm no air in the system. My pump acts squirrelly when I don't burp the air from the unused washers/dryer lines after winterizing.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 03-30-2018, 05:32 PM   #14
MacDR's Avatar
My Divertor Valve had a crack in it by the threads ..I just by passed it and my pump works great. I didn't replace the valve.
MacDR is offline   Reply With Quote
Old 03-30-2018, 05:49 PM   #15
Bene Gesserit Rule
Murbella7's Avatar
That shot of water is only what is in the outlet pipes, sitting there after the pump stops. If the check valve is faulty, the pump will not retain the prime.
Murbella7 is offline   Reply With Quote
Old 03-31-2018, 03:24 PM   #16
If he has the pre filter on the inlet side of pump, if leaking a little it would allow the water to drain back to tank. Check cup for crack and o-ring for damage.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 04-01-2018, 09:50 AM   #17
Thanks for the input everyone. I focused on the crimp connections on the inlet side and re-crimped them all. After 4 hours there was still prime, so I think I got it! If it happens again I will probably replace those crimp rings with something else.
pump, water, water pump
