03-01-2013, 10:58 AM
Water pumps
Unhooked this morning and noticed the water pump not working. No noise and water tank is filled. Any suggestions on troubleshooting the problem? Thank you
03-01-2013, 11:09 AM
Have you checked the fuse at the water pump?
03-01-2013, 11:12 AM
By the way ..... RBR is copyrighted! Lol
My racing engine shop is RBR RACING ENGINES.......
Turbs
CLASS "A" Senior Member
First time using this year? Could be the valve is still open for sucking up anti-freeze?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
03-01-2013, 11:16 AM
Also if there is air in the hw tank or lines the pump may run but you won't hear it.
03-01-2013, 11:21 AM
Wasn't sure where the fuse was. So it's by the pump? And we have used it since
it was winterized.
RBR are my initials. I have probably been using that a lot longer than you have! LOL!
03-01-2013, 11:22 AM
it was winterized.
Yes there should be a blade fuse right next to pump in a fuse holder.
Ron Benhart Racing engines.
03-01-2013, 11:23 AM
Not getting any water from faucets either
03-01-2013, 11:25 AM
Thanks! Will check that!
03-01-2013, 06:11 PM
Fuse was bad. Replaced it, it works fine. Wonder what blew the fuse??
03-01-2013, 06:28 PM
Its hard to say ........
load surge to fuse
weak fuse
What size fuse was it ?
03-01-2013, 06:29 PM
Size 10
03-01-2013, 06:40 PM
Max amps for the average shurflo pump is about 7amps so a ten should be fine .
See if it happens again and let me know.
TURBS
03-01-2013, 06:59 PM
Ok thanks for the help
08-10-2013, 11:05 AM
Similar problem 10amp water pump blowing. Trying to find out reason for fuse blowing. Removed pump inlet filter but no debris. Checked pump outlet hose no blockage. Their is kink in hose from fresh water tank but this was there since new 2011. I wonder if any filter at end of pipe in fresh water tank? FW hose is epoxied in place so might be hard to replace (would cure kink issue). Any other ideas to fix this issue?
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
08-10-2013, 08:48 PM
Denver, CO
Pump is bad, or impeller is stuck. either way pump has to come out. and be inpected or replaced.
Might want to check wiring also, cause a short will cause the same symptoms.
2017 Fuse 23T
