Old 03-01-2013, 09:58 AM   #1
RBR
Water pumps
Unhooked this morning and noticed the water pump not working. No noise and water tank is filled. Any suggestions on troubleshooting the problem? Thank you
RBR is offline   Reply With Quote
Old 03-01-2013, 10:09 AM   #2
TURBS's Avatar
Have you checked the fuse at the water pump?
Old 03-01-2013, 10:12 AM   #3
TURBS's Avatar
By the way ..... RBR is copyrighted! Lol
My racing engine shop is RBR RACING ENGINES.......
Turbs
Old 03-01-2013, 10:12 AM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
First time using this year? Could be the valve is still open for sucking up anti-freeze?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-01-2013, 10:16 AM   #5
TURBS's Avatar
Also if there is air in the hw tank or lines the pump may run but you won't hear it.
Old 03-01-2013, 10:21 AM   #6
RBR
Wasn't sure where the fuse was. So it's by the pump? And we have used it since
it was winterized.
RBR are my initials. I have probably been using that a lot longer than you have! LOL!
Old 03-01-2013, 10:22 AM   #7
TURBS's Avatar
it was winterized.
Yes there should be a blade fuse right next to pump in a fuse holder.
Ron Benhart Racing engines.
Old 03-01-2013, 10:23 AM   #8
RBR
Not getting any water from faucets either
Old 03-01-2013, 10:25 AM   #9
RBR
Thanks! Will check that!
Old 03-01-2013, 05:11 PM   #10
RBR
Fuse was bad. Replaced it, it works fine. Wonder what blew the fuse??
