Old 08-29-2009, 07:29 PM   #11
EastlakeRoo's Avatar
Don and Elaine, Do you have any photos of your set up that I can see?
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 08-30-2009, 11:05 AM   #12
Thanks for the reply. When you have time, Can you post a picture of the set up?
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 09-02-2009, 11:01 PM   #13
AKA KE2DX
Don and Elaine's Avatar
Will try and take some pictures of the many mods I've done, but it will have to be in mid-Sept. as we are leaving tomorrow morning for a 2 week trip.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
Old 09-15-2009, 07:49 AM   #14
Update
Originally Posted by fmielke View Post
Has ayone made a bypass to take the filter housing out of the line for winterizing. I know I hate the thought of winteriz.ing, but I want to be ready and I don't want to leave the housing inplace after the filter is removed.
A lot of readers voiced the opinion that this filter is in the wrong place and I agree. I purchased a 6 inch galvanized nipple, used some teflon tape and put it in place of the filter head which is so hard to get at under the sink. I then used a couple of adapters and now use the same filter outside connected to the main water inlet.
fmielke is offline   Reply With Quote
Old 09-15-2009, 11:25 AM   #15
CLASS "A" Senior Member
cfsoistman's Avatar
You may want to change that 6" galvanized nipple to (2) 3/4 CPVC Male adapters with a short piece of pipe between them. Galvanized pipe will rust over time where plastic CPVC will not. I work in the HVAC field and have seen many water heaters tied in with galvanized pipe and it's corroded with rust inside the pipe. Same goes for galvanized trash cans. Must importantly that nipple is after the filter now so there's nothing to keep the rust out of your drinking water.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 09-16-2009, 07:01 AM   #16
Thanx for the heads up, I have replaced the galvanized nipple with a 6" PVC nipple.
Old 10-05-2009, 09:28 AM   #17
Wanted to share the following link with everyone as Camping World has a brand new item for this type of problem. http://www.campingworld.com/browse/s...391719&rewrote
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 10-07-2009, 07:03 AM   #18
This is an awesome solution for those who have not moved their filter to an easier accessable location. Why didn't I think of that??
Old 10-18-2009, 08:47 AM   #19
AKA KE2DX
Have finally gotten around to posting pictures of some of the Mods I've done, Including the water filter with the by-pass. These pictures can be found under the Mods thread.
Old 10-18-2009, 09:30 PM   #20
Sorry,
I dont get the antifreeze thing. This will be my first winter with an RV.
If I dump the water out of the holder and open the faucets, would that not work just as well? It allows for expansion, the same as a driping faucet on a house.
Do I need to drain the hot water tank as well, or is leaving the faucets open good enough?
Fencer is offline   Reply With Quote
