Old 08-26-2009, 03:08 AM   #1
Water Pur CCI-10CLW12 bypass
Has ayone made a bypass to take the filter housing out of the line for winterizing. I know I hate the thought of winteriz.ing, but I want to be ready and I don't want to leave the housing inplace after the filter is removed.
fmielke is offline   Reply With Quote
Old 08-26-2009, 08:22 AM   #2
bamasurveyor's Avatar
I just fill my filter canister with marbles. They take up all the excess space and save on anti-freeze.
John
Ted
bamasurveyor is offline   Reply With Quote
Old 08-26-2009, 08:42 AM   #3
After our burst this spring due to freezing DH talked to our dealer and they told him a way to bypass...sorry I don't remember. He was going to try it this weekend and if it works I will post what he did.
love2rvcamp is offline   Reply With Quote
Old 08-26-2009, 09:12 AM   #4
Campfire Master
I use a water heater bypass kit on mine. The kit had an 8" hose which was a little tight. Had I known at the time there was a 12" hose I would have used that one. Just a flip of the lever either sends water through or around the filter.
AVid
AVid is offline   Reply With Quote
Old 08-26-2009, 10:15 PM   #5
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Mine was full of antifreeze last winter. It froze, and broke all to heck!
If you do winterize with antifreeze....I suggest you fill your system, bleed the pressure off and dump that canister out...so there's room for expansion.
My cansiter was mounted under the bathroom sink. I took it out, and joined the two lines together. Now, I have an outdoor mounted cansiter which is easy to reach, and easy to winterize...just dump it out and put it away!
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 08-27-2009, 04:11 PM   #6
KyDan's Avatar
Mine is in the front crawl thru storage.
I did exactly the same thing--
Removed the filter.
Connected the lines.
Now us a whole house filter on my hose when I'm filling
the tank or on city water hookup.
If they weren't so cheap at Forest River, they'd put in
a bypass on the original filter setup!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-27-2009, 07:04 PM   #7
I'm going to try to get the proper fittings, T's etc to bypass mine with valves.
Max Power is offline   Reply With Quote
Old 08-28-2009, 06:42 AM   #8
EastlakeRoo's Avatar
I have a 21RS Roo with a built in Water Pur system. I'd be interested in knowing if there is a bypass I need to purchase or just winterize the RV with the filter housing attatched and letting it fill with Antifreeze and then when I'm done winterizing the pipestake the canister off and empty the antifreeze back in the jug. Will this option work too?
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 08-28-2009, 10:06 PM   #9
The Jolly Mon
NDJollyMon's Avatar
This option will work just fine. You may get some dilution of the antifreeze when it displaces the water in the lines, however. May not be full strength when you save it. DEFINATELY....EMPTY out the canister and reinstall. If some freezing does occur...it has a place to expand to. (I learned the hard way)
Pete (Jolly Mon)
Old 08-29-2009, 10:43 AM   #10
AKA KE2DX
Don and Elaine's Avatar
I removed my water purifier for this very reason, I went to Home depot and for $30,(refill fiters are $7) purchased a GE water filter which had a 3 position lever, Thru, Bypass and Stop all water.This was a direct swap out for the factory installed filter. I blow out all the water lines first and then simply put the lever in bypass when winterizing and remove the clear housing with the filter and proceed to winterize with a tee which I also installed that sucks the anti-freeze (with the pump providing the suction) out of the bottle and complete winterization takes about 10 min.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
