Old 11-05-2008, 04:38 AM   #1
Water Regulator
I have a fix water regulator I bought 8 years ago for camping and still using it. Question? should I replace it as a general rule due to age, as far as I can tell there is no signs of any problems yet.
Old 11-05-2008, 08:12 AM   #2
Head Rambler
As long as it's working reliably I wouldn't consider replacing it. Good quality regulators are designed to last many years. A good one should outlast you and I.
Gotta go campin!
Old 11-05-2008, 10:56 AM   #3
I agree with Bama Rambler, if your regulator is working OK I wouldn't replace it.
That being said, I bought a Watts model H560 adjustable regulator this summer. I have it set for 45PSI with the hot and cold spigots turned on full at the outside shower.
It has much more flow than the old fixed regulator I had.
I found it on e-bay for about $20.00.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 11-14-2008, 05:41 PM   #4
I also bought an H560 from Ebay and it's a considerable improvement over the cheap one I had been using.
Dennis
La Vernia, Texas
2007.5 Dodge 3500 Laramie, 4WD, Dually, 6,7L Diesel
2008 Forest River Sandpiper 375QBQ
dd5087 is offline   Reply With Quote
Old 11-14-2008, 07:57 PM   #5
Cyber Phrenologist
Radio's Avatar
I might be next. Wife complains about the lack of flow in the shower.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 11-14-2008, 09:02 PM   #6
Another question? If a water regulator fails, will it fail in an non operational mode which might be called a fail safe mode or will it open all the way as if there was no restriction? I think it would fail closed because of the safety issue but, I don't know for sure.
Old 11-15-2008, 08:13 AM   #7
Head Rambler
I've seen them fail both directions but they rarely fail high. Most times the spring fails and the unit completely shuts off the flow. In critical applications you always use two stage regulators and a pressure relief valve downstream.
Gotta go campin!
