Old 05-02-2016, 08:30 AM   #11
By pass valve
Yep. Just got my 2016 Surveyor back on Saturday from the dealer. I had that same issue, brand-new. Bad valve from the factory. Apparently not checked by the dealer because I discovered the issue at home - along with about 10 other items, pinched hoses, etc.
All good now. On board water works...city water works...potable tank disinfected, still need to mount bedroom tv. (oh, yeah, remember to lube the equilizer hitch. . . the dealer didn't mention that)
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 05-02-2016, 10:04 AM   #12
mike.t's Avatar
Originally Posted by Wolverine 1945 View Post
Didn't realize you needed the pump on when connected to city water.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-02-2016, 10:31 AM   #13
Who Dares, Wins
doc73's Avatar
He did not say he was hooked up to city water, said the water shot out. I think that is what threw us.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-02-2016, 11:21 AM   #14
mike.t's Avatar
You are correct doc. Looks like I need to read a bit more carefully.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-02-2016, 11:26 AM   #15
Kaadk's Avatar
Odd that it would only happen when there was demand at a faucet. Basically, the pump should kick on to pressurize the system and not kick off if not pressurized. As long as that check valve is stuck open, it shouldn't be able to pressurize and would be constantly running, shooting water out of the city water connection regardless of whether or not there was demand at a faucet.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 05-02-2016, 11:42 AM   #16
Who Dares, Wins
doc73's Avatar
I read it bunch of times, though I missed it!
I was wondering the same thing the more I thought about it. Maybe pressure seals it, drop (opening faucet) unsealed it and when closed the pressure eventually reveals? I dunno.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
Old 05-02-2016, 12:15 PM   #17
mike.t's Avatar
Did it do this prior to having plumbing work done?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-02-2016, 12:58 PM   #18
Kaadk's Avatar
I was thinking about this more while I was gone for lunch, I suppose it could be explained if the city water connection was installed on the inlet side of the pump instead of the outlet side. If it was plumbed that way, then it would explain it only coming out the city water connection when the pump is drawing water from the fresh water tank.
But if it was plumbed that way, whenever he uses the city water hookup that would be going through the pump and backfilling the fresh tank....unless it's one of those rigs with the selectable inlet. You know those ones where they have to switch between city hookup and filling fresh all though one?
Old 05-02-2016, 02:27 PM   #19
I was thinking about this more while I was gone for lunch...
Actually it wouldn't explain it. If the city water was incorrectly plumbed as you indicate, nothing would come out of it since it would be on the suction side of the pump. Now, if it were lower that the tank it would siphon, but all that still points to a bad check valve on the city water fitting.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-02-2016, 03:00 PM   #20
Kaadk's Avatar
It might be explainable if the check valve was installed in reverse. The way I'm picturing it as there's suction then the check valve closes due to the vacuum pressure, but as that's replaced with a draw from the tank occasionally the water pressure could force the backwards installed check valve open.
Kind of hard to explain, but this seems plausible. The failure side of this would be that if the check valve was installed backwards, it couldn't be used for city water....
pump, water
