Old 05-02-2016, 04:53 PM   #21
mike.t's Avatar
Looks like they figured it out (they haven't said anything) if not what type of plumbing work was done. Hello. anybody out there.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-03-2016, 03:25 PM   #22
Water Spraying Out
Mine happened at a dealer. DW turned on the pump to run some water. Sprayed out the inlet. Dealer said you need a new check valve. I replaced it that night. Noticed putting the screen back in that it pushed on the relief valve. Bent the screen to clear the valve. Worked fine. Never put the old valve back in to see if the screen was the problem.
Aeroguy is offline   Reply With Quote
Old 05-03-2016, 11:25 PM   #23
CombatYoga's Avatar
You guys nailed it!
He took the screen off and could see the check valve stuck open. Flicked it with his finger I believe and it closed.
Many thanks you guys!
CombatYoga is offline   Reply With Quote
Old 05-04-2016, 05:51 AM   #24
Wolverine 1945's Avatar
My Bad,,, I misread the first post !!!
Wolverine 1945 is online now   Reply With Quote
pump, water
