12-13-2018, 03:59 PM
water softeners
has anyone used a portable water softener and if so how did you like it ?
2011 F450 Dually 6.7 Powerstroke King Ranch 430 gears
12-13-2018, 04:06 PM
12-14-2018, 12:14 PM
Used one for a year, problem with ours was it really needs to be connected between the water filter and the trailer. Due to the location of our water filter we had to connect between tap and filter. This resulted in having to regenerate about every 10 days. Used a lot of salt....Best
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
02-10-2019, 11:27 PM
Hoping for a little more feedback on this topic. I had a knowledgeable RVfilter/softener guy, but he appears to have sold his business...
What is the difference in the regeneration process between models?
If I can tie it in after the filter system in the basement, can I just leave it in there all the time? Somewhat hard mounted?
Any difference in pressure drop or flow?
And, just straight table salt? How much?
Thanks in advance for any replies.
Trilogy 38RE
02-10-2019, 11:48 PM
I run a cameo disposable filter in advance of my softner, I have many I bout for $3 each so I am covered. I then run into my trailer. I always use the softener to fill the tank no matter the source. I regenerate mine after about 4 tanks fills or after a week at a rally running more water than normal. I use a box of table salt, 89 cents at Walmart,
B and B
02-11-2019, 12:01 PM
Is there a good source with customer service, or just pick one off amazon and call it a day?
How does the generation process work? Is it simply dumping salt in or is there more to it?
Trilogy 38RE
02-11-2019, 12:04 PM
Open the top, dump salt in and flush using a pressure reduced fitting, mine came with a Tee and little hole in a plug on one side. I saw one model where you removed the filter attached and put salt in the canister and attach a pipe to the centre to draw salt off the bottom, seems more complicated.
Rallies like Goshen often have a vendor will a deal, we bought ours there, still using it 6 years later.
B and B
02-11-2019, 12:30 PM
Guess you could keep it in basement but you might have to remove it to do regen. depending on basement size. You have to remove top to add salt and connect flush hose to drain.
Did not notice any pressure or flow difference.
Used regular salt from the grocery store, used two containers per regen. (think they are 2 pounds each, round paper container). Total cost was about $1.50 per regen. using Walmart brand.
Regenerated about every 7-10 days depending on water use. Took about 30 - 45 minutes to regenerate. This is why we stopped using ours, to much labor. Did like the results, just didn't last long.
From what I've read all RV size systems have to be manually regenerated and last about the same between regens.
2016 Champagne EL38
02-11-2019, 02:03 PM
I ordered mine from the manufacturer, support was not that good. Systems are not that complex. Put salt in wait 30 minutes, flush for 30 minutes. Use test strips to see level. Repeat when hardness level dictates. Best
2016 Champagne EL38
02-11-2019, 02:05 PM
Soft water is your water heater’s worst enemy.
Bruce
02-11-2019, 02:48 PM
So useful life is dictated by incoming water hardness, but also filtering prior to softening.
Looks like this one is quite popular:
https://www.amazon.com/gp/product/B0...I3UUIFGZ&psc=1
On The Go OTG4-DBLSOFT-Portable 16,000 Grain RV Water Softener
Would using a device like this allow you to complete the regeneration process directly into your sewer via garden hose? I understand the designed purpose is for those without blacktank flush, but it could be an easy way to eliminate a puddle in your site?
Trilogy 38RE
02-15-2019, 03:39 PM
After a brief but very positive conversation with my neighbour about the “On the Go” water softener, I have ordered one from Amazon. Estimated delivery is Wednesday, I’m going to add some quick connectors to expedite the regeneration process. I’m also going to try hard mounting in the basement, and see how that goes.
Trilogy 38RE
02-21-2019, 08:08 PM
So I got it all rigged in between the dual canister filter and the water manifold. Flushing through a garden hose into the flush port on the elbow worked great. Tested the water before, was over 50 grains per gallon. Now it is about 3 GPG. I ran a bunch of water through the hot water heater, and emptied the ice machine. Will ask my wife what she thinks after her next shower.
Trilogy 38RE
05-01-2019, 01:32 PM
I use the in go since 2015, I think it great never had a issue.
05-03-2019, 09:53 AM
I have had one for 3 years . They are great . I personally would not hard wire it into the basement. If a leak occurs you won't know it .
