Old 05-05-2016, 04:51 PM   #11
Are you absolutely sure it's the water? Reason I ask is because there's a new type of one-way drain valve that sits in a horizontal position, probably close to the down pipe from the sink, that might be holding stagnant water and allowing smell to waft up the drain when you start running the hot/cold. Ignore if you have a p-trap under the sink. Isolate the fresh water in a cup so you can do a smell test. If the fresh water, hot or cold, is smelling, then I have nothing to add.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 05-05-2016, 04:53 PM   #12
VinceU's Avatar
Originally Posted by Rags View Post
The water in my bathroom just reeks of rotten eggs. I have no issues with any of the other two sinks. The smell dissapates after running the water for several seconds but is still there. This is with both hot and cold. It doesn't matter if I'm on city or fresh water. I had issues with the hot water tank so that has been flushed too. Any suggestions? Thanks, Randy
Since the sink stinks and not the tap water, I've had a similar, recurring problem. My unit has two Hepflo traps from England, instead of trapping a couple inches of water, this trap uses a flexible diaphragm to prevent backflo. After awhile scum builds up and prevents closure and gases are free to flow through the sink. Easy fix is about 5 oz's of straight bleach and allow to sit 15 minutes or more. Rinse sink with stopper closed and save until time to flush down drain. Works every time.
Old 05-05-2016, 05:28 PM   #13
Fulltime family RVer
Another way I've tested is plug the drain in the sink and add 1/2" of water. This stops any smells from coming up. THEN run the water for a bit- if it stinks, it's the water; if not, it's the drain.
ependydad is online now   Reply With Quote
Old 05-05-2016, 05:32 PM   #14
Originally Posted by fonzie View Post
Check under sink if you have an air admittance valve that could be defective....
X2. Bet thats your problem if that valve is located in the cabinet under the bathroom sink.
Old 05-05-2016, 08:45 PM   #15
VinceU's Avatar
I don't think the air vent would stop stinking by adding a small amount of water down the sink.
Old 05-05-2016, 08:52 PM   #16
VinceU's Avatar
Mistake on valve mfg. it's made by HepvO in the UK. The valve does not live up to its claims. The unit in the shower allows heavy back flow and the sink requires cleaning every couple of months.
Old 05-06-2016, 11:34 AM   #17
fixing the stink
Go to home depot and purchase the PVC you need to replace the diaphragm with a regular p-trap. You lose some room, but loose the stink!
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 05-06-2016, 12:05 PM   #18
remove your adenoid in your hot water tank and clean or replace it sounds like too much iron in the water. Make sure it's filled before you turn back on .
selkirk awards is offline   Reply With Quote
Old 05-06-2016, 12:56 PM   #19
peterbilt's Avatar
where are you maybe sulphur water i know years ago i used to get some out west
2007 dodge ram 2500 2008 sabre 31 RKTS Knoxville Tenn
peterbilt is offline   Reply With Quote
Old 05-06-2016, 05:48 PM   #20
BBBlue's Avatar
I had the same issue. Flush Atwood Water Heater twice until the water from the drain was crystal clear. Flushed hot and cold water supply lines to washer/dryer, which has not been used. Still had the smell out of the bathroom faucets. Removed sink U trap and whoa! finally found the source. The buildup in the u trap and small straight section of piping from sink drain contain a nasty buildup. I cleaned both sections with bleach solution and now no smell. I will definitely put this on my bi annual list of thing to do. Hopefully, this can provide assistance.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
roo, water
