Old 05-06-2016, 05:54 PM   #21
Ford Idaho's Avatar
Originally Posted by TURBS View Post
Include the wh
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Yes!
Do the whole bloody system, low point drain outside shower even the kitchen spray hose if separate from the faucet.
Let the water/bleach sit in the lines for 14-24 hours then drain it all out.
Flush EVERYTHING at least twice.
Old 05-06-2016, 07:19 PM   #22
We found Peroxide to be the best disinfectant when put in the sink drain at night, let it sit there till morning and this will kill all the bacteria that has accumulated.
Also good to do this to all your sink drains when you have fruit flies in the house as they breed in the drains.
kenenn is offline   Reply With Quote
Old 05-06-2016, 07:37 PM   #23
W5CI's Avatar
I had the same problem with my Cedar Creek when I bought it used, just replace the anode rod and Flush it good and all will be ok
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 05-08-2016, 09:25 AM   #24
Wolverine 1945's Avatar
Does your bathroom sink drain have a P trap ???
Could your bathroom sink drain be working as a vent for the Gray tank ???
Are your Roof vents clear ???
Guess that might be a different smell hey ???
Wolverine 1945 is offline   Reply With Quote
Old 05-13-2016, 01:03 PM   #25
Water stinks in bathroom sink only
Thanks for all the tips! Dieselguy nailed it. I flushed the washer line and the smell disappeared. You mentioned capping it - like you I have no intention of putting in a wash machine. I would like to cap it as you suggest but I don't see, or can't figure out how to do that under the sink. I have a red and a blue line going to the taps and then a red line that come up from the floor and basically makes a u-turn through some short of valve and goes back under the floor. I suspect this may be the air admittance value fonzie talked about. Should I be looking to cap it at the back of the source i.e. control panel outside? I have a Sandpiper. Thanks again!
Rags is offline   Reply With Quote
Old 05-14-2016, 10:06 AM   #26
VinceU's Avatar
The u- turn valve is a nonreturnable vac breaker for water flush to the black holing tank. Since the washer drain pipe size 1 1/2", probably the only open sect needs to be capped, it's non pressure fitting and easy to seal up.
VinceU is online now   Reply With Quote
Old 06-12-2016, 07:38 PM   #27
Fulltime family RVer
Originally Posted by dieselguy View Post
Stinky bathroom sink water was / is pretty common on some Keystone products with what I described above. The rank water that just sits and sits in the washer line leaches into the bath sink faucet and "boy howdy" does it stink. Sanitizing the water lines is good practice, but doesn't help if you overlook an unused washer line. If you'll never use that line ... cap it and be done once and for all.
This was it for us. I finally got around to sanitizing everything and boy howdy, when we ran the hot water in the W/D hookups, it was almost bad enough to make you puke! My poor wife had her head in the closet filling a bucket with water.
I don't think I'll cap the lines, but do think I'll install ball valves to turn off those lines in case I ever install a W/D.
Old 06-12-2016, 10:42 PM   #28
Kenny kustom's Avatar
Ball valves is a great idea.
Easy to get to in the basement.
Thanks for the idea..
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-12-2016, 10:58 PM   #29
I might finally breakdown and get the shark bite fitting tool or whatever it is that is needed for them. Supposedly, they're super easy to use.
Old 06-13-2016, 07:01 AM   #30
This might work too.
Easy to drain as well.
Name:   ImageUploadedByForest River Forums1465819273.914121.jpg
2016 Sabre 36QBOK
roo, water
