Old 05-05-2016, 01:04 PM   #1
Water stinks in bathroom sink only
The water in my bathroom just reeks of rotten eggs. I have no issues with any of the other two sinks. The smell dissapates after running the water for several seconds but is still there. This is with both hot and cold. It doesn't matter if I'm on city or fresh water. I had issues with the hot water tank so that has been flushed too. Any suggestions? Thanks, Randy
Rags is offline   Reply With Quote
Old 05-05-2016, 01:10 PM   #2
TURBS's Avatar
Sanitize fw system
1/4 cup of bleach per 15 gallons of water
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 05-05-2016, 01:32 PM   #3
dieselguy's Avatar
If you have a washer/dryer option installed and never use the washer, this may be your issue. I had the same stinky water on my SOB's bath faucet. The washer plumbing was T'd to the bathroom sink's plumbing. When I cracked open the washer faucet, it reeked of stale water. The smell went away after flushing the line, but came back a few months later. I capped the washer lines at the bathroom sink area as we never had interntions of a washer / dryer. Smell never returned.
dieselguy is offline   Reply With Quote
Old 05-05-2016, 01:41 PM   #4
Always Learning
Interesting. I'm having the same issue- rotten eggs smell with just my hot water tap in the bathroom.
We ran bleach through most things and it only knocked things back a little- we did NOT include the washer/dryer lines or water heater itself.
Old 05-05-2016, 01:45 PM   #5
TURBS's Avatar
Include the wh
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-05-2016, 01:49 PM   #6
TURBS's Avatar
Use this periodically.https://www.google.com/search?q=camc...&client=safari
We use it once a month
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-05-2016, 02:24 PM   #7
dieselguy's Avatar
Stinky bathroom sink water was / is pretty common on some Keystone products with what I described above. The rank water that just sits and sits in the washer line leaches into the bath sink faucet and "boy howdy" does it stink. Sanitizing the water lines is good practice, but doesn't help if you overlook an unused washer line. If you'll never use that line ... cap it and be done once and for all.
Old 05-05-2016, 02:56 PM   #8
fonzie's Avatar
Check under sink if you have an air admittance valve that could be defective....
Fonzie
Old 05-05-2016, 03:13 PM   #9
As said above, put bleach into hot water tank, as much as possible. I pour it into the drain on the HW tank. Fill it up with water, let sit for a day if possible, then run it through your water lines, including outside shower. Empty the tank, fill it up, drain and then fill it up again. Run fresh water through the water lines also. I would also recommend putting bleach into your water hose that you use for city water hook up.
Pipeman is offline   Reply With Quote
Old 05-05-2016, 03:22 PM   #10
Dazed & Confused
M&K Hoffman's Avatar
Many times the rotten egg smell in hot water comes from a reaction with the anode in the heater. Here is an article on the problem: How to Fix Rotten Egg Smell in your Water
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 05-05-2016, 04:51 PM   #11
Are you absolutely sure it's the water? Reason I ask is because there's a new type of one-way drain valve that sits in a horizontal position, probably close to the down pipe from the sink, that might be holding stagnant water and allowing smell to waft up the drain when you start running the hot/cold. Ignore if you have a p-trap under the sink. Isolate the fresh water in a cup so you can do a smell test. If the fresh water, hot or cold, is smelling, then I have nothing to add.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 05-05-2016, 04:53 PM   #12
VinceU's Avatar
Since the sink stinks and not the tap water, I've had a similar, recurring problem. My unit has two Hepflo traps from England, instead of trapping a couple inches of water, this trap uses a flexible diaphragm to prevent backflo. After awhile scum builds up and prevents closure and gases are free to flow through the sink. Easy fix is about 5 oz's of straight bleach and allow to sit 15 minutes or more. Rinse sink with stopper closed and save until time to flush down drain. Works every time.
Old 05-05-2016, 05:28 PM   #13
Always Learning
Another way I've tested is plug the drain in the sink and add 1/2" of water. This stops any smells from coming up. THEN run the water for a bit- if it stinks, it's the water; if not, it's the drain.
Old 05-05-2016, 05:32 PM   #14
X2. Bet thats your problem if that valve is located in the cabinet under the bathroom sink.
Old 05-05-2016, 08:45 PM   #15
VinceU's Avatar
I don't think the air vent would stop stinking by adding a small amount of water down the sink.
Old 05-05-2016, 08:52 PM   #16
VinceU's Avatar
Mistake on valve mfg. it's made by HepvO in the UK. The valve does not live up to its claims. The unit in the shower allows heavy back flow and the sink requires cleaning every couple of months.
Old 05-06-2016, 11:34 AM   #17
fixing the stink
Go to home depot and purchase the PVC you need to replace the diaphragm with a regular p-trap. You lose some room, but loose the stink!
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 05-06-2016, 12:05 PM   #18
remove your adenoid in your hot water tank and clean or replace it sounds like too much iron in the water. Make sure it's filled before you turn back on .
selkirk awards is offline   Reply With Quote
Old 05-06-2016, 12:56 PM   #19
peterbilt's Avatar
where are you maybe sulphur water i know years ago i used to get some out west
2007 dodge ram 2500 2008 sabre 31 RKTS Knoxville Tenn
peterbilt is offline   Reply With Quote
Old 05-06-2016, 05:48 PM   #20
BBBlue's Avatar
I had the same issue. Flush Atwood Water Heater twice until the water from the drain was crystal clear. Flushed hot and cold water supply lines to washer/dryer, which has not been used. Still had the smell out of the bathroom faucets. Removed sink U trap and whoa! finally found the source. The buildup in the u trap and small straight section of piping from sink drain contain a nasty buildup. I cleaned both sections with bleach solution and now no smell. I will definitely put this on my bi annual list of thing to do. Hopefully, this can provide assistance.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
BBBlue is offline   Reply With Quote
roo, water
