Old 04-18-2016, 06:13 AM   #1
hlywud's Avatar
Water system
I have a 2011.. 39.9 Forest River Salem Park model.
Does anyone have a water diagram.
I have never had a problem with the water system, this year I attempted to turn it on and all I hear is gurgling, does not have water coming from the taps or toilet doesn't fill.
There appears to be a gate valve in the intake that doesn't allow water to get through?
Any suggestions would be appreciated.
hlywud is offline   Reply With Quote
Old 04-18-2016, 06:31 AM   #2
I doubt you will find any print for your Water system! There might be a Check valve at your city water inlet,behind the little screen! You supply No location info so if Freezing comes into play! Youroo!!
Old 04-18-2016, 06:40 AM   #3
wmtire's Avatar
X2, I am assuming you must have winterized it by the way you said I attempted to turn it on this year. Do you have a water filter, and if so, did you do anything to it in the winterization process last year?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-18-2016, 06:50 AM   #4
hlywud's Avatar
I had it winterized by the same guy the last 3 years, I will have to call him.
Old 04-19-2016, 06:09 AM   #5
hlywud's Avatar
Fixed...seem that there is a spring loaded plastic clip just inside the main intake, it was broken so we removed it. Water now.
Thanks for all the suggestions.
Old 04-19-2016, 06:20 AM   #6
Like I said in my 1st reply,this is your Inlet check valve! If you are "ever" going to use your "Pump and Tank Water" you will need to Replace this valve or Place a screw a Plug in the City water Inlet,OR" Water will Come Out the Inlet"! Youroo!!
Old 04-19-2016, 06:21 AM   #7
AquaMan's Avatar
that most likely is your check valve for your city supply line. If you ever have to use your onboard pump & tank (not sure if you have one in a destination trailer), water will come out that connection.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-01-2016, 07:31 AM   #8
hlywud's Avatar
Talking
situated in a Park with Municipal water supply, not needed,
water
