08-05-2015, 03:29 AM
Water System questions
Hi, we just purchased a 2012 Salem Sub Zero and can not locate the water pump. Can someone let us know where it is located? We also ran into a problem while filling our water tank. Until we placed a shut off valve on the 2 pipes near the blank tank valve the water was draining out as quick as it went in. Are these low point drains, overflows, or ? Thank you for helping to educate two newbies.
08-05-2015, 03:56 AM
Just a member
We think you really meant the 'black tank valve.' Shut offs are nice but not entirely necessary.
Are these low point drains...
Very likely. As to the location of your water pump: Switch on the pump, turn on a tap/faucet and follow the noise. It won't take long to determine which panel it's buried behind.
And BTW... to the forum!
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
08-05-2015, 04:38 AM
I don't think I've ever ever seen anyone on this Forum, that's owned a Sub Zero trailer.
Is that one of those ice fishing models?
08-05-2015, 04:40 AM
Thank you for answering so quickly!
We can't even find a switch for the water pump. Every switch we've found is labeled but none say water pump. Is it possible this this particular model is all gravity fed? Our water tank has an 85 gallon capacity.
08-05-2015, 05:02 AM
Its an oil field model
Hi, I hope there is another owner of a Sub Zero out there . It was designed for oil or gas field workers in ND I think. The insulation is amazing.
08-05-2015, 05:11 AM
The Salem (Ice Cabins) have NO Fresh water/Black/or Gray Tanks! I think you have a (Limited Edition/Special Order/Oil Field Special)? Youroo!!
08-05-2015, 11:37 AM
Do you get water from faucets and/or toilet when not connected to an external supply line? If so, do you hear a pump running? If so, open a faucet, and follow the noise -- it will surely lead you to your pump. I would guess that your access panel will be on or next to a lav, sink, toilet, or shower, and the panel will be on the INSIDE of the rig.
By the way, I saw a question about whether it could be "gravity fed". The only way that would be physically possible is if the supply tank is located ABOVE the highest faucet. Unless your tank is on the ROOF, that seems unlikely.
2006 Wildwood LE 28FKSS - 2015-
Read my weekly Computers & Technolgy Q&A feature It's Geek To Me!
08-05-2015, 12:48 PM
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
08-05-2015, 12:53 PM
never heard of this model and never seen a post about them, here or on any other RV forums i belong to.
08-05-2015, 12:57 PM
Georgia Rally Coordinator
Yep that's a new one. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-05-2015, 01:13 PM
Some sub zero' have tanks and some don't. You may have low point drains only and they should either have a plug in them or a valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-06-2015, 06:31 PM
The sub zero is ot listed this year at FR website/ 12-15 models are listed forbsale on the web, all with 85 gal fw tanks.
Frank & Brenda
