Old 04-15-2011, 09:50 AM   #11
sherdep's Avatar
My Mini Lite has the vent next to the fill hole and it is hooked up as well. As a matter of fact I tested it out yesterday when I filled my tank up and watched the water coming out the vent and then checked to see if the tank was full and it was.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-15-2011, 04:07 PM   #12
That is how they SHOULD work, I do believe. I know I have the tank under the sink, and I can open a cabinet door, and clearly see the level in the tank. The vent...or some type of vent for air is required to replace the water as it is used up, and for overflow. Randy
Old 04-15-2011, 06:49 PM   #13
yvesm's Avatar
Originally Posted by prof_fate View Post
it's not the heating element, it's the sacrificial anode. Apparently our trailer which has many nice options has the base water heater - propane only and manual start via go outside and light the pilot light.
there is no hose down there to go to the fitting. I just don't like the idea of an open hole to my water supply!
on the water pump - if I run a mix of hot/cold water I get no pulsation but on all hot or all cold I get the pump to 'cycle' on and off.
Remove the flow control washer from the faucets, just unscrew the end of the faucets where the water comes out and take out that little washer with the small hole in it. I replaced all of the faucets on my camper with better quality ones.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 04-16-2011, 09:18 AM   #14
jimh's Avatar
sounds like ur fresh water tank issue is solved.
u can buy an anode rod that has a drain on it. may want to look into that...will keep u from pulling it to drain the hw heater. my anode is being replaced this year for the frist time sense bought (2002). i still had abt 1/3 of it left. depends on the water as to how long it will last.
now the sink. i had that problem with my trailer (2002 cardnal). i also had a few drops of water under my sink that i couldn't find for a couple months. the faucet mix area had a small crack in it (area between the valves where hot and cold combine before it goes up to the faucet out). faucet was replaced with an identical one (warranty) and problem disappeared for abt 5 yrs. when it started doing the sputtering again (like air in it) i also found the drops of water again. replaced with one that had a metal mixing area. it's only been a couple years but the problem hasn't returned.
i felt like i may have cracked the mixing area bleeding the air out of the system too fast. that is the only faucet with a riser before it comes out. the air will cause a hammer as it and water are pushed alternately out the sink faucet.
jimh is offline   Reply With Quote
Old 04-16-2011, 10:16 AM   #15
prof_fate's Avatar
I"ll look at the faucet for a restrictor - took forever to fill the coffee pot this morning!
Lots of wind and rain last night - blew out the water heater at some point as we had hot water last night and none this morning.
I assume if the pilot goes out the gas flow is cut off, right?
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-21-2011, 06:26 PM   #16
prof_fate's Avatar
Update...
Overflow: Got some time today to go peeking about and under the sink, where the waterpump is located, is where all the water connections congregate.
FR put some caulking in the overflow port on the outside fill (from inside) so I got that out (the screen just pops out the outside so it was easy) and all the hoses go through the floor right there, plugged with some expanding foam. A few minutes to cut that away and I should be able to run a proper overflow hose. Might be able to poke it through the foam - it has to stop raining here long enough to crawl under the TT. Normal April is 2.1" of rain and we've had 4.2 so far with 2" more predicted for fri/sat and the 7 day forecast is for 7 days of rain.
As for a restrictor -our kitchen sink has the 'fancy' pull out sprayer head as part of the faucet. Unless the restrictor in the base of the hose under the sink there's no way to get at the nozzle/outlet itself.
2011 Grey Wolf 28BH
Old 04-21-2011, 06:50 PM   #17
Herk7769's Avatar
I could not find that part either. I just removed the ones in the bathroom.
The kitchen one must be in the base somewhere.
HAM CALLSIGN - KC3FFW
Old 04-21-2011, 11:05 PM   #18
kevinC's Avatar
I had much the same issue with our new TT. I crawled under and found the hose from the tank to the pump had two kinks on it as the assembler stretched the hose way to tight. Replaced the hose and all was well. It's am hour drive also for us one way to the dealer.
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
