Old 09-02-2016, 12:38 PM   #1
Water Taste
The water in my travel trailer has an unpleasant taste both when hooked up to outside water and when using the fresh water tank. I've done the sanitization thing with bleach and flushed it with clean water but the taste is still there. Any thoughts on how to remove it?
Jeff M is offline   Reply With Quote
Old 09-02-2016, 12:48 PM   #2
AquaMan's Avatar
Try adding a filter to you water supply.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 09-02-2016, 12:57 PM   #3
Just A Member
EDABEUT's Avatar
How long did you leave the bleach water in the lines??? Add the bleach water to your fresh water tank and then use the water pump to fill all the lines just like you are winterizing it. Leave it in for a day or 2 then flush it out. I had the same problem when I bought my TT. Water had been left in the lines and it really smelled and tasted bad. I had to do the bleach treatment twice before it went away. The worst thing was the pullout kitchen faucet rubber hose. If you have one also make sure no water sits in that hose when not using the TT.
Ed & Brenda
2015 Coachman Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 09-02-2016, 01:02 PM   #4
Boy Jeff you don't supply Much Info! Did you install a Element in your filter? Do you have a filter? If you installed a Element what one/type is it? There are Many types and kinds just for Taste,as well as Micron sizes! Lots of Members filter incoming water that is going into the F/W tank and direct supply! They also add a Drinking /Cooking filter in the kitchen! There have been LOTs of Posts,please do a Search at Top of page! Youroo!!
Old 09-02-2016, 01:30 PM   #5
just drink beer and save the water for flushing lol
maybe its just the water you are putting in there too.
bpa098 is offline   Reply With Quote
Old 09-02-2016, 01:52 PM   #6
Adding baking soda to about 10 gallons of fresh water helped the taste a little bit. We just use a 5 gallon jug of water from home for cooking and drinking.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 09-02-2016, 02:10 PM   #7
Beer on Cheerios is an acquired taste. After the 1st bowl, who cares ( about anything). 😉
SilverbackMel is offline   Reply With Quote
Old 09-02-2016, 03:59 PM   #8
well i prefer milk on my cheerios, not bad tasting water lol
Old 09-02-2016, 04:06 PM   #9
Filter
Most all campground water really tastes horrible. Buy yourself an in-line RV water filter that attaches right on the end of your water hose. They are cheap on Ebay and last about 1 whole season.
D-Man is offline   Reply With Quote
Old 09-02-2016, 05:57 PM   #10
AquaMan's Avatar
We usually drink bottled water, but if I do drink from the rig, it's through the fridge dispenser. The water filter in that is removes just about everything. Will take the pink out of the antifreeze.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
water
