Old 07-04-2016, 09:34 PM   #1
DW's Retirement Plan
DaGrinch's Avatar
Water TOO Hot - Atwood Water Heater
On our most recent trip to Raystown Lake, DW complained about the hot water being too hot. I told her I would check it out.
I opened the door outside of the RV and I'll be darned if I could see any type of thermostat to regulate the water at the tap.
I have run a search but have not come up with anything remotely similar to this issue. If it has been discussed before, could someone point me to the thread?
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 07-04-2016, 09:45 PM   #2
RSchleder's Avatar
I'm not trying to be a wise guy here. Wondering what your owners manual has to say about it. If you don't have the manual, most of the time you can find it on-line to read or download. Good luck.
Days camping (2016)----181 days
Days camping (2017) --- 14 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-04-2016, 10:06 PM   #3
chideock's Avatar
Internet search for Atwood Water heater manual MPD 93756 and see if that suits.
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 07-04-2016, 10:23 PM   #4
Sky&Scuba
kendive's Avatar
Good vid to watch...
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-05-2016, 01:01 PM   #5
drelec's Avatar
Atwood 93105 Adjustable Electronic Thermostat
This worked for us. Had to use some silicon heat conductive paste between tank and sensor to get good contact. They should include a small tube with the thermostat. I now have a lifetime supply.
Ordered from Amazon.
Super Lube 98003 Silicone Heat Sink, 3 oz Tube, White
drelec is offline   Reply With Quote
Old 07-05-2016, 09:13 PM   #6
DaGrinch's Avatar
No, you raise a good point. I do look at the owner's manual and do some research on my own. But you know what? Some of the best darned ideas come from the members of the forum. Never thought about the t-stat replacement until I watched the video kendive posted. Didn't know there was such an animal as an adjustable t-stat until I read drelec's post.
Thanks to everyone for your contributions!
Old 07-06-2016, 01:46 AM   #7
drelec's Avatar
Just a heads up on installing the variable thermostat, you have to bend the metal tabs that hold the original thermostat so its not easy to go back to the stock 140F thermostat. The metal hold down clip is a pain to get hooked in place. The adjustable thermostat only has letters for temperature setting, A B C D E. I think we ended up at B for 120F at the faucet.
Old 07-08-2016, 06:44 PM   #8
drelec's Avatar
Photos of Variable Thermostat on Attwood
Photos
ID:	113491   Click image for larger version
Old 08-13-2016, 08:36 PM   #9
Chief tinkerer
Gidyupgo's Avatar
Same problem here. I have a question about another use for the wh bypass valve. We are concerned with our toddler grandchildren being burned by the super hot water in our Sunseeker. Any reason we can't or shouldn't crack this valve open a little to blend cold into the hot supply lines to a safe temperature? I had ordered a Sloan blend valve to do this but when I pulled the wood panel off to look at plumbing the valve in I see this diverter valve and thought "hey, why not"?
Gary
2017 SunSeeker 3010DS
Gidyupgo is online now   Reply With Quote
Old 08-13-2016, 08:43 PM   #10
Chief tinkerer
Gidyupgo's Avatar
Pic
Gary
heater, water, water heater
