Old 07-06-2013, 10:23 PM   #1
Feldhege's Avatar
water tooo hot!
DW and I are camping with our two little boys. We went to use the hot water to wash our hands and it is way too hot. I have it on electric right now. Any way to adjust the temp. Don't want to risk having the little guys get burned. Or is it not meant to be left on? First time campers.
Robb Feldhege
2009 Chevy Duramax 2500HD
2018 Signature UltraLite 8295WS
If your best was good enough today........
It won't be tomorrow.
Feldhege is offline   Reply With Quote
Old 07-06-2013, 10:27 PM   #2
"Roughing it since 2000"
There is no adjustment to my knowledge. The thermostat should control temp while leaving it on. We leave ours on and the water does get very hot.
2007flagstaff is offline   Reply With Quote
Old 07-06-2013, 10:50 PM   #3
Denver, CO
garbonz's Avatar
keep the little one away from the hot water, no other choice. since the tank is so small the mfg's want it hot to last.
2017 Fuse 23T
Old 07-07-2013, 12:05 AM   #4
Fulltime family RVer
If you have winterization valves to bypass your hot water tank, you can partially open it to allow cold water to be drawn in when you run the hot. I am doing it for the first time on this trip and it mostly helps. There've been a few quirks here and there, but mostly good and I'll definitely continue to do so.
ependydad is online now   Reply With Quote
