Old 07-28-2013, 11:02 AM   #21
Herk7769's Avatar
Originally Posted by slide5r4fun View Post
Awesome. Thanks Herk! We're headed to camping world today to get some supplies and plan on picking up a couple of ten footers and the 25'. We're looking to downsize our hose bins.
Your "hose bin" will disappear.
Next step is a 10 footer to paint black for the turboflush.
HAM CALLSIGN - KC3FFW
Old 07-28-2013, 11:16 AM   #22
NELA
Weezer's Avatar
Originally Posted by bakken View Post
I saw a hose on tv that goes flat when the pressure is released. It has two stiff ribs with soft sides that collapse. looks like it would roll up real easy.
There is also that silly hose that shrinks that you see all the time on tv, but I think it wouldn't last. Probably just surgical tubing in a sock.
You are correct, those green shrinking hoses do *not* last. I stepped on ours *ONCE* while it was inflated/full of water and it split...about a 2 inch split. Just the "inner tube" split, not the outter fabric.
Won't buy another one, that's for sure. It lasted about a month. I used it for watering my many hibiscus plants on the back patio.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-28-2013, 06:24 PM   #23
I looked at one of those "green shrinking hoses" at the grocery store. The inside diameter of that thing is so tiny, or maybe it was just the exit orifice that was tiny to build pressure inside so it would expand. Either way, I can't imagine you'd get much water flow thru it.
Old 07-28-2013, 07:42 PM   #24
jtstromsburg's Avatar
I use one for my black tank flush and it's great for that. I've only used it about 10 times so far so not sure of durability. I link herks idea of painting a flat hose black for that purpose.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-28-2013, 08:13 PM   #25
slide5r4fun's Avatar
Another great idea. I did go to CW today and got 2 ten footers and the 25'. Not only will I take your advice and get another 10' piece and paint it black but I also plan to do the sewer hose mod with 5" square pvc fence post you and others have posted about on another thread. Thanks again for the ideas!
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 07-28-2013, 08:16 PM   #26
I use 25 ft hoses and roll them up then connect the ends togother and secure them with velco. Most of the time one 25 will work unless you are at a state park that is when I pull more out.
R Whitlow is offline   Reply With Quote
Old 07-28-2013, 08:30 PM   #27
That's we've done up to this point but I like the idea of rolling the hose up on the real instead of wrestling it into a bin. Plus, I'm trying to reduce the size of the bins needed to store hoses and accessories. Gonna give it a shot!
Kevin & Janine
Old 07-28-2013, 08:55 PM   #28
Just ordered 2 10' and a 25' from Camping World. Great idea Thanks
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 07-28-2013, 09:02 PM   #29
B and B's Avatar
I pick up 50 ft standard white RV from Walmart for 11 bucks CDN, I store them in mesh sacks (oranges, firewood etc) come in. I have used 4 of them at a Provincial Park to fill the tank. Also use the free dealer hose(only 1/2 inch) for black water uses.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-31-2013, 03:30 PM   #30
Old Enough to Know Better
gasman6674's Avatar
I roll my 50 ft white hose up on an electrical cord reel works very well. I use a 25ft for most of my full hook ups. I try not to boondock if i dont have to :-)
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
