Old 09-08-2016, 03:30 PM   #1
( WaterPur CCI-5-CLW12 ) water filter housing split in two - easy on the road fix
This week i had a water filter housing split and empty the full load of water from my tank into my trailer while i was out walking. Here's an easy fix you can do without replacement parts. I simply removed the filter assembly (4 philips screws) and then removed the inlet water nipple (plastic fitting that goes from the screw on collar into the filter body) and just used this little fitting to connect the inlet and outlet lines together - essentially bypassing the filter and using the small plastic nipple to connect both lines together. All repairs completed with a Leatherman multi-tool. No teflon tape needed as there are rubber gaskets inside each water line. See images below
ID:	119737   Click image for larger version
ID:	119738   Click image for larger version
ID:	119739   Click image for larger version
ID:	119740   Click image for larger version
Fueler67 is offline   Reply With Quote
water, water filter
