Old 06-18-2012, 12:21 AM   #1
crushor's Avatar
WaterPur - tank drains
Well, as I am still learning...via long distance...about our TT, I have a couple of questions. According to the owners manual that was emailed to me by FR (which is missing about 30 pages), it speaks about a water filtration on board our '06 Cedar Creek Silverback. Product name is WaterPur. Any thoughts on where this cartridge would be located? It is said to filter the whole fresh water system. I have looked, but not been successful in locating it. Our CC is a 31LRLS. My wife works for the TT dealer, and she informed me that they carry the cartridge...nevertheless, not sure of its location. In the meantime, we are filtering at the fill point of the trailer.
Secondly, while at home the last time I wanted to make sure that I would know the drains on the TT. I found the black water drain, with two control handles, one marked black water and the other not marked, would this be the grey water drain that uses the same end drain off the trailer? Strangely enough, my wife found the unmarked valve handle pulled. Fortunately we have not used the facilities on board yet, however she has poured some water down the drain of the kitchen sink.
Lastly, fresh water tank drain...I cannot locate this either, unless it is the small blue hose that is hanging about 1/3 the way back from the front of the box. It has a small valve on the end of it and the hose looks to be about 3/8" ID. If this is in fact the freshwater drain, then it is not possible to drain through the sanitation hose...ie...black water, grey water, then fresh to relatively clean out the sanitation hose.
Thanks guys. I certainly do appreciate the information. I have been reading posts on this site like crazy to learn all that I can.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 06-18-2012, 06:19 AM   #2
TURBS's Avatar
Filter is almost always right next to your water pump.
Black and grey may come out of same pipe but are obviously seperate above
Fresh water drain is what u have found.
Old 06-20-2012, 12:13 AM   #3
crushor's Avatar
F1 100turbo, thanks for the reply. Nine days til maiden voyage. Trying to get all my ducks in a row.
Old 06-20-2012, 05:43 AM   #4
TURBS's Avatar
No problem!
Good luck!
