Old 01-23-2016, 09:47 AM   #1
Watts water pressure regulator
I'm looking at buying a adjustable Watts water pressure regulator with gauge for my TT. What model do i need and what fittings to hook up to a water hose ?
dryhorn2 is offline   Reply With Quote
Old 01-24-2016, 03:12 AM   #2
Fulltime family RVer
No idea. I bought an assembled kit from www.rvwaterfilterstore.com. If I remember in the morning, I can take photos of mine if it helps.
Old 01-24-2016, 06:57 AM   #3
Ford Idaho's Avatar
This one is user ready with adjustable flow and a gauge.
http://www.googleadservices.com/page...d%3D403-493368
Old 01-24-2016, 07:23 AM   #4
nomad297's Avatar
That's a pretty handy little PRV. I wonder how long it will last with a continuous high incoming pressure. That probably doesn't really matter for most RVers, though, as I have found most parks to have pretty reasonable water pressure. The higher the incoming pressure compared to the reduced pressure, the shorter the life of the PRV.
I service several areas with street pressures of 100-120 psi. Most of these houses have PRVs installed, reducing the pressure to around 60 psi, and I have found the life of quality PRVs, such as the various Watts models to be about 8 years. They just wear out and it doesn't make sense to rebuild them, so they are replaced. I have noticed that the larger (actual physical size, not pipe size) the PRV, the longer it lives. This is why I question the lifespan of the PRV you linked to -- it is very small.
Bruce
Old 01-24-2016, 08:07 AM   #5
Ford Idaho's Avatar
Bruce
Yes it is small when compared to a unit used in a stick house but it is lite weight which may be important.
How long it will last would depend on how much it gets used, with my luck it would make it one day past the warranty from the manufacture....
Camp world sells one a little cheaper.
https://www.google.com/url?sa=i&rct=...53726628021464
Might be a better option price ways but I am not sure of the quality.
Old 01-24-2016, 08:15 AM   #6
nomad297's Avatar
I would go with the Watts any day. They have proven to be the best PRVs in houses, so I am sure it will out perform any other brand of similar size.
Bruce
Old 01-24-2016, 08:35 AM   #7
Kaadk's Avatar
That's the one I use. I've only had it a year but so far it's holding up. Can't compare it to the watts, but it's better than the non-adjustable $4 water restricter the dealer had thrown in when we first bought our rig. At least now I can dial in per campground and try to keep the pressure up in the shower. With the restricter, we had terrible pressure all the time.
One thing to note is that it can be heavy. I've been at some sites where the weight of the regulator and our brass 't' was pulling the tap away from the post when the tap is just stapled to the post. A couple of zip ties come in handy for situations like those.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 01-24-2016, 09:04 AM   #8
lgray's Avatar
Agreed on the Watts quality. We bought a small household Watts on clearance (see link below) from Lowes. Added brass fittings to adapt from water hose to inch. This set up requires a small 3 foot second water hose, with the unit left at the spigot or locked inside the water bay. We just felt that a household unit used in an RV, should last forever while providing optimal water flow and pressure protection....with a total cost of about $40.00.
http://media.wattswater.com/ES-LF25AUB.pdf
lgray is offline   Reply With Quote
Old 01-24-2016, 09:07 AM   #9
Ford Idaho's Avatar
I was in one that had a water system like that, State Highway 64 between Williams, AZ. and the Grand Canyon.
The morning we left in one of the unoccupied sites the faucet blew off the plastic pipe water was like 3-5 feet in the air, panic ensued.
Did not hang around long enough to see how it worked out....
Old 01-24-2016, 09:19 AM   #10
nomad297's Avatar
You'll pay about twice that for a LF25AUB-Z3 now. Maybe you bought yours prior to the NSF/ANSI 372 regulations going into effect.
Bruce
pressure, water
