Old 01-11-2018, 04:36 PM   #1
DouglasReid's Avatar
Well, It Got ME!
Here i was so happy, after the last freeze we have a descent weekend and we decided to come to Bayou Segnette State Park in Westwego, LA (suburb of New Orleans)
We set up and everything was going well until I noticed water on the bathroom floor. Hurriedly sopping it up and looking for the leak at the same time I was baffled. DW found it when I went for more towels. The Toilet Flush Valve.
I had blown the entire system free of water using air and even the toilet. Obviously not enough. Fortunately there was an RV Dealer/Parts supply close by, Bent's RV in Boutte, LA who had just what I needed. $59 later DW has a toilet that works without spraying water up her backside. Life is good again!
Will have to remember to unscrew the water line from now on.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-11-2018, 04:43 PM   #2
BandJCarm's Avatar
You know, I did that this year (unscrewed the valve) because I'd lost mine TWICE on the previous camper. I thought I was smart.
THEN when I went to put in the antifreeze, I slapped my head. Duh! I can't pump in antifreeze through a line that is disconnected. It'd go all over the bathroom floor. So, I connected it back.
BUT, I have a spare valve, and am quite proficient at putting it in. I'm a bit east of you, come on over and I'll give it to you! LOL
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 01-11-2018, 04:52 PM   #3
Fulltime family RVer
Heh, went through 2 of these - 1 each after my first 2 winters. I now carry a plug for the toilet water line so if the toilet leaks, I can have water everywhere else in the camper until I run for 1.
Fortunately, itís an easy replacement.
Old 01-11-2018, 05:19 PM   #4
I think they call that a Bidet. :trink 39:
wildcatter is offline   Reply With Quote
Old 01-11-2018, 05:21 PM   #5
Saving this thread as an example when people ask if they should use AF after blowing out their lines with air.
Iwritecode is offline   Reply With Quote
Old 01-11-2018, 05:44 PM   #6
Lins's Avatar
Yep I do both, but we see -40 so it's a no-brainer.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is online now   Reply With Quote
Old 01-11-2018, 05:55 PM   #7
BandJCarm's Avatar
Yeah, really.
First time winterizing myself. I blew the lines out. THEN I added antifreeze. The amount of water in a lot of lines after blowing them out was amazing.
Now, after snowbirding (!!!), here I sit with water FINALLY hooked up and danged if another FULL WEEK of subfreezing temps is not supposed to hit! Next year, I am moving further south.
FROG AR-0019-242
Old 01-11-2018, 06:08 PM   #8
And that's how I ended up in Venice, FL for Christmas.
We were supposed to be in New Orleans and slowly make our way across the panhandle during the first 2 weeks of January. Instead, we dropped like 4 reservations and ran for southwestern Florida.
Old 01-11-2018, 06:19 PM   #9
Agree but "Good Luck" on changing anyones mind! Youroo!!
Old 01-11-2018, 07:04 PM   #10
Now a "Top Member"
EdJunior's Avatar
Uh oh. I never thought about that. Never had a problem with my old TT, but this is the first really hard freeze since I bought the "new" 5th wheel (7 years ago!). I planned on hooking up the water before I went anywhere anyway. Now I will for sure.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - Still too new
