Old 06-28-2015, 08:30 AM   #11
Yeah I have the valves open, first thing I checked. But now looking around online it seems to be I should keep them closed and then dump them when it's full. I'm new to this rv thing. Learning these lessons the hard way it seems.
Gchaine is offline   Reply With Quote
Old 06-28-2015, 08:30 AM   #12
Who Dares, Wins
doc73's Avatar
Originally Posted by Yarome View Post
I found one of these does a bit better job than a rotating tank wand.
I agree I have two sitting in my garage now unused.. The straight solid one and a bendy one.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-28-2015, 08:32 AM   #13
Who Dares, Wins
doc73's Avatar
yes that is correct. I will sometimes leave the gray open if we are all getting showers and baths while doing dishes but NEVER leave the black open unless you want a poo mountain forming in the tank (think concrete).
2015 ChevyHD D-Max
Old 06-28-2015, 08:44 AM   #14
Well I probed down the hole with a coat hanger, I can get it about three feet down and it feels thick the hole way. Do you think if I get the reverse flush valve to would clear this up or do I have to dig it all out from the top? I'm getting very discouraged with my progress so far
Old 06-28-2015, 08:48 AM   #15
Who Dares, Wins
doc73's Avatar
I am not sure the Grey Wolf because I have never looked... But my RW had a shelf if you will where the pipe bent and then went into the tank. It was not a straight drop into the abyss. Could you be just hitting the shelf? Has the fluid lever changed at all up top?
2015 ChevyHD D-Max
Old 06-28-2015, 08:49 AM   #16
No the reverse flush valve will do nothing for your problem. I bet you have a mountain forming. You need a flush stick and just keep working it till it breaks loose. I don't envy you.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 06-28-2015, 08:50 AM   #17
Who Dares, Wins
doc73's Avatar
If your tank is "empty" bellow I think from the top would be safest. The back flush may not remove the clog and might not be able to even reach the clog if it is up high on the pipes. (remember you do not want boil over!!)
2015 ChevyHD D-Max
Old 06-28-2015, 08:59 AM   #18
Ford Idaho's Avatar
This will not be a quick easy job so a little patience will go a long ways.
Water is your black tanks best friend so close the valve and add as much as you can and add a waste digesting treatment and let it sit 24 hours.
Drain the tank and then use one of the wands poste above with the tank valve open because it is going to take a lot of water.
Old 06-28-2015, 09:01 AM   #19
dan-nickie's Avatar
Dig it out from the top. If you let it go down into the tank you may have a worse problem.
BTW, how long have you had the RV and how long have you been putting the wipes down the toilet.
When we first got ours, we clogged it up with toilet paper. Had to fish it out with a coat hanger also. We learned that we were not using enough water when flushing.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-28-2015, 09:03 AM   #20
dan-nickie's Avatar
I think you are getting different answers because some are thinking 'tank' clog and some are thinking 'toilet' clog.
Dan
