The hot water heater bypass valve was spraying water when I turned on the water for the season.
The first photo shows the bottom of the valve with a rubber O-Ring sticking through. The bottom rotates when the handle is turned. That is where it was shooting out.
I’d like to replace all 3 plastic valves with brass, but it’s a very tight space to reach.
In the third photo I noticed a white threaded plastic connector at the end of the white inlet and the red outlet. Can these be unscrewed and easily disconnected?
Then in the fourth photo they go into the heater. Can that be disconnected?
If so, I’m thinking I could remove all 3 valves and rebuild the Pex with better valves and reconnect.
I bought a pex ring cutter and fastener, along with a pex cutter, new rings, new valves, and pex piping.
Anyone with experience fixing these?
I feel like removing the whole heater is scary.
It’s a 6-gallon Surburban has/electric.
