Old 04-14-2014, 09:56 AM   #1
WH empty with LP burner on
I have a similar problem. 6 gal. Suburban water heater, electronic ignition, heater drained, propane on. My grand daughters were playing in the camper and accidentally turned the propane WH switch on. I did not notice it until the next morning as I walked by I heard the igniter sparking and the burner firing up. I guess that this has been going off and on all night. Might I have some damage from this running without water in it?
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 04-14-2014, 12:43 PM   #2
KyDan's Avatar
Short answer is Yes. Maybe. Do you feel lucky? With no water in the
tank the burner tube will get VERY hot before the tank itself is heated enough
to "satisfy" the LP thermostat. Since you heard it still trying I guess the
hi limit has not tripped.
Your burner tube might be damaged or not.
You can try connecting to city water and un-winterize your WH by
replacing the drain plug/anode (if it's out now).
Switch the valves from winter mode to summer mode.
Open a hot water faucet and let out the air to fill the HW tank.
Watch the tank from the burner side and see if it's leaking.
No leaks- maybe you're ok.
Flip the LP back on and see if it lights and heats normally.
Of course you know now that you should not let kids play in your RV
unless LP and electric are OFF!! Even then they probably need some supervision.....
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 04-14-2014, 12:45 PM   #3
Gravity challenged
Bob_Loblaw's Avatar
I wouldn't think so. As long as the electric element wasn't on you should be fine. The gas flame would just heat the tank (obviously much faster than if were full of water) to the temp set by the thermostat and then shut off. Hopefully you escaped with nothing more than lighter propane tanks.
Jim & Susan
2017 Flagstaff 832OKBS - Days camped 2019: 4
2013 Silverado 2500HD LTZ Duramax
Try to learn something about everything and everything about something. - Thomas Henry Huxley
Bob_Loblaw is offline   Reply With Quote
Old 04-15-2014, 10:31 AM   #4
Well I filled WH and flushed it out several times. At first the water was brown like tea. After several flushings it cleared up and looks good. Electric and propane heating modes working fine. I guess I got lucky, no apparent damage, maybe some scorched debris in the tank had discolored the water. The morning I opened the WH cabinet in the inside it was pretty warm. Lucky, I guess that it could possibly have started a fire if something had malfunctioned. Lesson learned.
cabranch47
1999 Ford F150
Old 04-15-2014, 01:14 PM   #5
Gravity challenged
Bob_Loblaw's Avatar
Great news!
Glad there wasn't any permanent damage. That's one of those learned lessons that stay with you.
Jim & Susan
Old 04-15-2014, 02:38 PM   #6
KyDan's Avatar
Thanks for the follow up. Often folks post a problem and we try to give
advice and never hear from them again.
We like to know the "rest of the story".
Glad you're OK.
Let the camping season begin!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-15-2014, 02:53 PM   #7
Fulltime family RVer
Now that it has a happen ending- mind me hijacking and asking how you tested the electric heating vs. propane heating? I've got a bit of a theory that my electric element may be burnt up, I just don't know how to test it...
Old 04-15-2014, 03:33 PM   #8
Turn the propane off, run the hot water out of the water heater and turn the electric side on. If you don't get hot water in about 20 minutes, the element is toast!
Old 04-15-2014, 03:50 PM   #9
Ok. That was my simple plan- thanks Coot.
Old 04-15-2014, 03:50 PM   #10
wmtire's Avatar
Doug, page 20 of the service manual may help you, including the ohms for a good element.
http://dutchmen.com/image/data/docum...ice_Manual.pdf
It could possibly have other problems besides the element (hi-limit tstat, switch)
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
