Old 04-21-2013, 08:43 PM   #1
Steve & Phyllis
SteveBingham52's Avatar
The handle at the top is a "hot water heater bypass"? So when would you use that? The little handle in lower right isn't labeled so I have no idea what it might be. It is a 2012 Sandpiper 315re.
SteveBingham52 is offline   Reply With Quote
Old 04-21-2013, 08:46 PM   #2
Steve & Phyllis
Sorry trying to post picture but can't figure out how to. It is a Sandpiper 315re
Old 04-21-2013, 08:46 PM   #3
Dave_Monica's Avatar
You'd bypass the water heater when you're pumping antifreeze through the water system. Is there supposed to be a picture attached to your post?
Dave
Old 04-21-2013, 08:47 PM   #4
Steve & Phyllis
Dave trying to figure out how to post the picture. I have it on my profile under pictures.
Old 04-21-2013, 08:54 PM   #5
I copied the instructions for adding pictures...perhaps it will help.
Dave
Edit: the photo in your profile is too small to distinguish anything.
How to add photos to a post
  • Click reply and scroll down to bottom of text box.
  • Click "go advanced" add text to message window and then scroll down.
  • Click "Manage attachments" A separate window will pop up.
  • Click "browse" Then select the file to be uploaded. Be sure that the photo is appropriately sized. 620 x 620 pixels (or smaller) and no more than 50K. Forums software will automatically reduce the size, but smaller size photos will upload much faster. You may select several photos to upload at the same time by repeating the last step.
  • Click "Upload" After pics have loaded close the pop-up window
  • Click "submit reply" to mount the text of your message - photos will automatically appear at the bottom of your post.
How to embed an image stored on another site:
You can do this by using image tags. Upload the image to a service like imageshack and then copy the URL of the image and put that between [IMG] tags. That will work well, as long as the host site stays in business and doesn't disable your image for overuse of bandwidth etc.
You can also paste in the location of a photo stored here in a photo gallery.
To do this: Paste the url of the image into your post. Then add the following code on either side of the url (with no extra spaces):
[IMG]url here[/IMG]
The image will appear where the url was in your text.
Old 04-21-2013, 08:56 PM   #6
Herk7769's Avatar
Forest River Forums - FAQ
You can also use the "paperclip" icon in the advanced menu to upload to the post directly.
Lou and Laura - Shopping for a Camping Buddy
2008 GMC Sierra 30000HD Crewcab SB Allison Duramax
HAM CALLSIGN - KC3FFW
Old 04-21-2013, 08:57 PM   #7
Steve & Phyllis
Old 04-21-2013, 09:01 PM   #8
AquaMan's Avatar
My guess would be that the unlabeled valve is the freshwater tank valve. You close this valve to pump from from the winterization hose to suck from your RV antifreeze bottle. The hot water bypass does exactly that, bypasses hot water tank for winterization, so you don't fill tank with antifreeze.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 04-21-2013, 09:24 PM   #9
Steve & Phyllis
Thanks. I will try it out with a bottle of water to see. The instructions are not very complete with these campers. The walk through is just a blur in my brain. Too much info too fast.
Old 04-22-2013, 06:37 AM   #10
Commercial Member
huntr70's Avatar
The lower right handle looks like it could be the fresh water tank drain. It looks connected to a blue water line.
Could also be a low point drain, but then you should have 2, 1 for hot and 1 for cold.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
