Old 11-02-2014, 03:49 PM   #11
Phat Phrog Stunt Crew
elind's Avatar
Those drains have a 1/2" cap on the ends. If there is clearance under them you can put a 1/2" ball valve on them instead of the cap and make it easier drain.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 11-02-2014, 08:21 PM   #12
Steveinthehills's Avatar
Thanks for the information. I probably have room for the 1/2" ball valve. I really appreciate your time.
Steve
steve
Steveinthehills is offline   Reply With Quote
Old 11-03-2014, 08:18 AM   #13
Brother Les's Avatar
Originally Posted by Steveinthehills View Post
Here is a photo of the drain lines at the front of the trailer. About 18 inches inboard of the white capped drain is another drain line with a black cap on it. Both drain clear water. Attachment 65784
steve
What does the lower sticker say in your picture?
The water hose with the white cap 'to me' would look to be the Fresh Water drain. The other hose that is 18 inches inboard with a black cap is the question that I have. When opening the white hose white cap line, does gallons and gallons of fresh water come out (assuming that the FW tank is full). What about the black cap line 18 inches inboard?
I am 100% sure that the first pic of the lines in the back are you low point drain. 98% sure that the white line, white cap is Fresh Water drain. The question is what is the 'black cap' line drain go to?
Brother Les
Old 11-03-2014, 08:35 AM   #14
Could the one 18 inches in be the Fresh Water breather tube? Should that even have a cap on it?
Brother Les
Old 11-03-2014, 08:40 PM   #15
If memory serves me the drain with the black cap will drain gallons of water. The drain with the white cap will drain only several gallons of water. What I think is the drain with the black cap is the holding tank water and the drain with the white cap is another low point plumbing drain. So I drain them both and not worry. Thanks for all your input. The people in the "Frog Club" have been most helpful to me in my RV owner's journey. Attached is a photo.
Steve
Name:	ImageUploadedByForest River Forums1415068789.406308.jpg
steve
Old 11-03-2014, 08:46 PM   #16
elind's Avatar
My white line = fresh water low point drain
blue line = cold water low point drain
red line = hot water low point drain
2014 Wildcat 327ck
Old 11-03-2014, 09:49 PM   #17
Thank you for the information and your time.
Steve
steve
Old 11-04-2014, 02:01 AM   #18
Witch Doctor's Avatar
If I where you and you were going to install drain valves I would do it in the basement being that if you get caught in a freak freeze like I did in Florida last year mine froze and broke. Now I close the valves in the basement and leave no water in them at all. The great weak point when you get 24 degree weather where it suppose to be 75 degrees.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-09-2014, 08:44 PM   #19
RVGeorge
George Creekmore's Avatar
Ok if I drain low point lines, then close refill with the pink stuff then drain again will this also get the water heater ready for winter or do I still need to pull out anode rod? Living in east Tn area. Also what about leaving the bath vent open 1/2 way for camper breathing ?
Name:	ImageUploadedByForest River Forums1415587346.409188.jpg
ID:	66153, Click image for larger version
Name:	ImageUploadedByForest River Forums1415587406.466880.jpg
Popeye 2013:
George Creekmore is offline   Reply With Quote
Old 11-09-2014, 09:35 PM   #20
Drain all low point lines. Bypass the water heater and pull out the anode rod. I would not put antifreeze in the water heater just leave it empty. I would blow out the water lines with air then run the pink stuff through the lines including the outside shower. Lastly I would pour some antifreeze in the sink and shower P-traps, black water tank and in the toilet.
Steve
drain
