Old 11-02-2014, 01:24 PM   #1
Steveinthehills's Avatar
What are these drain Hoses?
They are located at the left rear of My Solaire 2001SS. In the trailer behind the hoses are the water heater, refrigerator, bathroom sink and shower? They are not the low point of the plumbing as that water valve is located at the upper left hand side of the trailer. Any help would be greatly appreicated. I'm in the process of winterizing the RV.
Thanks, Steve
Name:	ImageUploadedByForest River Forums1414956276.155163.jpg
steve
Steveinthehills is offline   Reply With Quote
Old 11-02-2014, 01:40 PM   #2
Those are your low point drains - open them and then purge air through the system and most of the water should come out of these drains.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 11-02-2014, 01:44 PM   #3
Brother Les's Avatar
Thanks, Steve
Attachment 65769
steve
Water valve? as in one at the upper left hand side of the trailer? That does not seem to be a 'drain'.
Low point drains are not on the upper of anything.. they are at the lower areas of the unit. There are two low point drains. one for hot water and one for cold. As the picture shows, those two drains are very close to the water heater, sink, shower, etc. Those to me do look like you low point drains as they are in the same (correct) area as my last unit.... in the back. When winterizing, drain your fresh water tank, drain water heater and then raise the front a few inches higher than the back and open all of the faucets (to breath) and open both of those drains and let the unit drain.
Brother Les
Old 11-02-2014, 02:46 PM   #4
Campster's Avatar
Those are definitely the low point drains to your unit. With the pump off and no city water connection remove the caps open a couple of faucets and the water will drain out of your plumbing system.
Campster is offline   Reply With Quote
Old 11-02-2014, 03:24 PM   #5
Thank you for the quick response. I drained the two lines and about a quart of water came out of each line. I finished up the job with reading the owners manual, used compressed air to blow out the water lines and then RV antifreeze. Last year the trailer was sent back to the factory for warranty work and the factory performed the winterization.
Thanks, Steve
steve
Old 11-02-2014, 03:30 PM   #6
Thanks, Steve
steve
Here is a photo of the drain lines at the front of the trailer. About 18 inches inboard of the white capped drain is another drain line with a black cap on it. Both drain clear water. Click image for larger version
Name:	ImageUploadedByForest River Forums1414963820.460959.jpg
steve
Old 11-02-2014, 03:32 PM   #7
Thank you for your reply. I really do appreciate your time in getting back to me.
Steve
steve
Old 11-02-2014, 03:33 PM   #8
Herk7769's Avatar
That "other" valve is most likely your fresh water tank drain.
HAM CALLSIGN - KC3FFW
Old 11-02-2014, 03:34 PM   #9
Thank you for your time in getting back to me. I should be all squared away for the time being.
Steve
steve
Old 11-02-2014, 03:35 PM   #10
I'm sure that you are correct. Thanks for the time in getting back to me. I really do appreciate it.
Steve
steve
drain
