Old 04-02-2016, 05:03 PM   #11
Rupkin2's Avatar
Originally Posted by waianaegal View Post
and hanging just to the upper right corner of the face plate are 2 wires, yellow and white with plugs at the end. Can't tell where they come from because they wind out of the large pile of spaghetti wires. wondering if they could be used to add an outlet that should have been there but they didn't put it in... since the face plate is there... I could maybe add the outlet into the basement. it would be very handy to have power in the basement storage.
Thanks... if nothing comes from this I did learn how to post a pic in a thread/reply.
My first thought would be that they are live and the worker just capped them off, maybe they were initially for an additional socket, or power source for extras.
If you know how maybe get a volt meter and check it out.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 04-02-2016, 09:13 PM   #12
dea49's Avatar
Looks as though yellow is positive.
dea49 is offline   Reply With Quote
Old 04-02-2016, 10:26 PM   #13
If it was 110VAC, it would Romex type wiring (2 wires plus a ground in the same jacketing insulation, like the blue wire for the electric element in my water heater in the pic below), not separate wires.
2011 Traverse LT, 3.6L, FWD
Old 04-03-2016, 03:45 PM   #14
thanks
I've got about 5 weeks til I hit the road again for my next volunteer spot and my sons are electricians going to hope to get both 12v and a 110 outlets in the basement... woohoo...
waianaegal is offline   Reply With Quote
Old 04-03-2016, 05:27 PM   #15
Two wires 12 volt.
They could very well be for an artic pack install.
harleyjs is offline   Reply With Quote
Old 04-03-2016, 05:35 PM   #16
arctic pack
I have heated holding gray and black tanks. The switch is right by the othEr controls. With the water tank enclosed I wouldn't think it would need heating. I will check other models. And see if theres something else down there.
Old 04-05-2016, 04:29 PM   #17
I'm with "rockfordroo" about the faceplate, someone dropped it at the factory and just grabbed another one to keep the line going. As far as the wires, I've done some electrical work on friends RV's and found the wiring to be something weird from unit to unit. The RV manufacturer's do not follow any electrical code that I have ever studied. Here is my 2 cents worth: The wires in the photo that are capped off were made into a wiring harness which was placed in your unit. This same harness can/could be used on an infinite number of units whether motorhome, 5-er, or pull trailer. I"m also betting that the yellow wire is a 12vDC hot wire and the plain white wire is the 12vDC ground. Using a wire tester for 12 volt circuits will confirm this. The bottom line: Don't worry over them, they are fine.
Thurman is offline   Reply With Quote
Old 04-05-2016, 04:48 PM   #18
Georgia Frog Rally 2018
aceinspp's Avatar
Better watch out FR going to start charging you for the extra parts LaterRJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
