Old 04-28-2016, 08:01 PM   #1
What hooks up here?
Just bought a 07 Palomino yearling! First-time owner of a camper.
2 Questions about the attached picture:
1. The left "hole" goes to the fill hole on the exterior of the pop-up. What type of tubing can I use to connect it?
2. What does the left side attached too? I have not had a chance to test the shower yet... The sink works fine.
Thanks for the help!
Sorry the picture loaded upside down...
Name:	2016-04-28 19.27.22.jpg
ID:	106412   Click image for larger version
Name:	2016-04-28 19.24.44.jpg
jschway is offline   Reply With Quote
Old 04-28-2016, 08:16 PM   #2
GLCM Warrior
Lefty59's Avatar
As you mentioned the larger one is for the fill hose. The one pointing down on the left appears to be the drain valve for the tank and my thought is that the black one on the upper right is the overflow valve.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 04-29-2016, 09:53 PM   #3
GLCM Warrior
Lefty59's Avatar
Try this Amazon.com: Smooth-Bor 101 Flex-Fill 1-3/8" x 10' Hose: Automotive or something like it to connect your fresh water fill opening to the tank. You'll likely need a couple of large hose clamps too.
Best wishes.
2014 Wildcat 312QBX
Old 04-29-2016, 11:33 PM   #4
MNtraveler's Avatar
If that's the overflow tube, I don't like seeing that open and underneath the unit. All manner of road water, salt and dirt could get in there as well as bugs etc. I would cover that over, but not tightly so if it does overflow it can still burst out.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-30-2016, 12:19 AM   #5
GLCM Warrior
Lefty59's Avatar
I agree. Might add a piece of hose with a one way check valve inline with it. That should do the trick.
2014 Wildcat 312QBX
Old 04-30-2016, 05:57 AM   #6
bubbles's Avatar
Would not be a good idea. That is the vent tube and typically just a mesh fabric is secured over the opening. It's a misnomer to call it an overflow but it will let you know when the tank is full.
Old 04-30-2016, 07:08 AM   #7
Normaly you would have a hook up like this http://www.dyersonline.com/jr-coloni...ater-dish.html . The small hole on the side is for the vent and has a screen on it to stop bugs getting in.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-30-2016, 12:07 PM   #8
Whiteknight's Avatar
On my TT the tank vent has a small hose that terminates to a hole with a screen over it next to the tank fill on the side of the trailer. Like Happy Vibe said.
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
Whiteknight is offline   Reply With Quote
Old 04-30-2016, 12:24 PM   #9
bubbles's Avatar
So, when you see water coming out that little hole do you take it as your tank being full?
Old 04-30-2016, 02:22 PM   #10
The black fitting goes to the water pump. Overflow would come out the same one you are filling with. This is a Pop Up correct? Our Santa Fe had this set up also.
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
