Old 02-26-2019, 03:48 PM   #1
Retired Old Fart
dward51's Avatar
What is the black "sealant" around rubber LP gas line?
Does anyone know what sort of sealant they use around the rubber gas lines where it enters the water heater to connect to the burner fitting? It's black but not totally solid, but very difficult to remove. Looks like some sort of troweled on mastic more than a caulk. They used the same thing on our refrigerator LP line which is also rubber.
I need to drop these lines down so I can reinstall the trailer underbelly and I want to use the correct sealant on the lines when I put them back in place. I have failed to figure it out in google searches. It has a very aggressive bond to the appliance frame and the gas line (black rubber lines so I need to make sure the replacement is compatible with rubber). It's not the blown in black poly expansion foam like used in the underbelly.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 02-26-2019, 04:01 PM   #2
Head Rambler
It's most likely either SikaFlex 221 or maybe 291 or it could be Geocel polyurethane, but I'm not positive of the number possibly GC66103.
Gotta go campin!
Old 02-26-2019, 04:01 PM   #3
D W
D W's Avatar
It's Black Insulating Foam. "Dow Great Stuff" - Available at Lowe's.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 02-26-2019, 04:38 PM   #4
Thanks. I didn’t realize Lowe’s carries the black version. I only found the off-white stuff at Home Depot.
In this case, I am assuming he is referring to the soft rubbery caulk-type glossy sealant that is behind the door in the water heater
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 02-26-2019, 06:45 PM   #5
Retired Old Fart
dward51's Avatar
No, the stuff I'm talking about is *NOT* "great stuff" foam. I'm familiar with that as it was used to tack down the underbelly sides and seal the pipe penetrations. This is something totally different.
So if it's likely a polyurethane sealant, I can just pick up some black poly sealant at the local big box store and use that? Or just use about any "caulk"?
Old 02-27-2019, 01:39 PM   #6
Head Rambler
Yeah, you can pick up some sealant at most big box stores.
Gotta go campin!
Old 02-28-2019, 12:30 PM   #7
Tom48's Avatar
If we are talking about the sealant around a penetration I suppose there are number of choices. If we're talking about where the propane line attaches to the Appliance I'm wondering why the joint wasn't just treated with the appropriate gas line grade of Teflon tape? Teflon tape is always my go-to guy am I missing something?
Tom48
In Sunny So Cal /w
2004 SD F250 now BULLET PROOFED
2017 Sandstorm 250 TH, with
8 wheel TST TPMS and
The Hot Air Balloon RESTLESS
Tom48 is offline   Reply With Quote
Old 02-28-2019, 03:00 PM   #8
Just as confused as you
Scrapper's Avatar
dward51, if you can post a picture it will help a lot as I don't believe others are understanding what your talking about. I don't know what it is but like you said it is not a foam spray insulation. It's more like a plasticized rubber applied with a chalking gun.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 02-28-2019, 03:34 PM   #9
That sounds like butyl to me.
https://www.amazon.com/butyl-tape/s?k=butyl+tape
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-01-2019, 01:42 AM   #10
Retired Old Fart
dward51's Avatar
This is a youtube video another FR forum member posted on his Girard tankless water heater install, but he shows the exact same sort of seal in his video at the bookmarked point in the video. I'm thinking it's a polyurethane sealant from the way it looks. If you push on it, there is a little give like it's flexible but it is solid not like butyl tape. Video should be cued at the correct point for him to talk about and show the sealant.
https://youtu.be/y_NjAkEi69A?t=297
black, gas, seal
