Old 04-13-2016, 08:21 PM   #1
MNtraveler's Avatar
What is this?
A red plastic item found in the hot water heater compartment when de-winterizeing. It seems to fit in the out flow portion of the pressure relief valve. However, it doesn't seem to feel any purpose and doesn't want to stay in there.
Name:	ImageUploadedByForest River Forums1460596849.119481.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-13-2016, 08:27 PM   #2
egladden's Avatar
That is the cap that the valve is shipped with to keep debris out of it before installation they must of failed to discard it
egladden is offline   Reply With Quote
Old 04-13-2016, 08:30 PM   #3
Looks like an FME (Foreign Material Exclusion) plug. Fills the the water connection holes in the water heater until they're ready to screw in the fittings. Keeps crap out of the water heater until it's installed. You can throw it away.
They come in all types and sizes. See here:
https://www.google.com/search?q=prot...xTrxs0AzUwM%3A
2011 Traverse LT, 3.6L, FWD
Old 04-13-2016, 10:39 PM   #4
MNtraveler's Avatar
Thank you both!
2016 Forester 2401R
Old 04-13-2016, 10:44 PM   #5
Yep, just a thread protector, just removed one from my relief valve and chucked it.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 04-14-2016, 04:21 AM   #6
World Wide Wanderer
wahoonc's Avatar
Agreed, thread protector from the relief valve, mine is still in there, just toss it.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-14-2016, 06:52 AM   #7
Years ago I had a new Ford F150 and I wanted to change the transmission fluid. All went well but I found this plug looking thing in the bottom of the transmission pan. I thought it must have fallen out some where so I looked and looked. I could not find any place it would seem to go, so I just put the pan back on, filled it with fluid and all was well. I held on to that plug thinking any day my transmission would just give up on me because that part was missing. Well, a year or so later I found out that Ford uses that at the bottom of the dip stick tube because the units are filled with fluid and then assembled upside down. They then insert the dip stick which pushes out this plug. The plug just sets in the bottom of the pan until someone like me finds it.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 04-14-2016, 05:33 PM   #8
MNtraveler's Avatar
Well, this red thing is open at both ends, so it might protect the threads but wouldn't keep stray material out!
Name:   ImageUploadedByForest River Forums1460673208.572715.jpg
2016 Forester 2401R
Old 04-14-2016, 08:06 PM   #9
Attachment 104911
If you look at my link in Post #3, you'll see there are hundreds of types/sizes/colors of these things. There are some to keep the threads protected (for a piece of pipe that you can look through and check for foreign material, for example) and some to keep stuff out (and maybe protect threads, too).
Old 04-18-2016, 05:13 AM   #10
World Wide Wanderer
wahoonc's Avatar
The red one is just to protect threads...
I work in industrial construction, you will see these things by the thousands when the pre-assembled process piping comes in. Those are typically full covers/plugs to protect the interiors of the piping from debris and the threads from damage.
Aaron
Aaron & Rhonda
