Old 08-29-2016, 12:53 PM   #11
Forester Fred's Avatar
Originally Posted by Wolverine 1945 View Post
So does the one hose have an open end some where ???
You should have the white flexible hose - look at the photo up a couple posts. That's the open end that goes in the antifreeze jug. I'm surprised your dealer didn't explain all that to you when you bought the rig. Mine made a big deal out of how it would draw up the antifreeze using the pump.
2015 Forester 2301 - Chevy
Skip & Deb - Denmark, ME & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 08-29-2016, 02:54 PM   #12
Originally Posted by RedLdr1 View Post
On most units I've seen the Red and Blue lines going through the floor with valves are the Low Point Drains for the hot and cold water pipe systems. Look and see if those two lines dump out under your motor home. If so they are your drains. The fresh water tank normally has a separate white valve for its drain.
The anti freeze system normally is connected to the water pump with short white hose attached to it. There will be a switch / valve to connected to it to select the fresh water tank or the anti freeze pick up hose.
I've attached a picture of what my MH has to show the color code and what it looks like... The locations vary by model but the colors are fairly standard.
That looks almost identical to mine. One suggestion, take a look at the hinge on the black plastic door that closes off the plumbing. Mine fell off last winter while bouncing across I40 and other various bumpy places in Arizona, New Mexico and Texas. Turns out FR only put the hinge on with body molding tape. Mine now has pop rivets holding it in place.
Old 08-29-2016, 03:30 PM   #13
RedLdr1's Avatar
Why am I not surprised... Thanks, I'll check it out.
Wayne and Christine
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium
RedLdr1 is online now   Reply With Quote
Old 08-30-2016, 07:37 AM   #14
Wolverine 1945's Avatar
I see that in post #9,,, I was asking about post #1 !!!
Wolverine 1945 is offline   Reply With Quote
