Old 08-27-2016, 04:00 PM   #1
What is this valve?
I'm preparing to take our new 2017 Sunseeker 3050 for our first trip.
There is a valve in here that I can find no documentation for, and as its at a 3-way junction I'm not sure what position it should be in. It could appear to be open in either position. The other position is straight up.
The red hose below it is not connected to this valve. It just looks that way because it's directly behind the valve.
The blue hose bottom right comes out of the right side of this valve and is the drain for the fresh water tank, and it has another valve of its own at the very bottom, and is currently open
Maybe I missed it in my 14 lb stack of manuals, but the only reference to plumbing in the owners manual is very generic as it may apply to any number of different models...
Skyjerk is offline   Reply With Quote
Old 08-27-2016, 04:09 PM   #2
Looks like the water heater bypass valve - used during winterizing . In the position shown, it is directing cold water into the water heater via the blue hose. Turning the lever ninety degrees upwards would bypass the water heater.
VTX Al is offline   Reply With Quote
Old 08-27-2016, 04:18 PM   #3
DW's Retirement Plan
DaGrinch's Avatar
That's my take on it, also.
Might go out and see if I have the same thing on my 3010DS a little later.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 08-27-2016, 07:02 PM   #4
Thanks for the info!
Cheers,
Chris
Old 08-27-2016, 08:34 PM   #5
Captain America's Avatar
Looks like a water heater winterizing bypass valve.
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 08-27-2016, 09:18 PM   #6
I think it could be the valve to select fresh water from tank or antifreeze draw using water pump. Do you have an outside connection for antifreeze?
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2016: 19 nights
Miles traveled in 2016: 2,575
uhduh camping is offline   Reply With Quote
Old 08-27-2016, 09:36 PM   #7
Forester Fred's Avatar
It's for drawing antifreeze out of the jug. I've got the exact same setup on mine. When you close that valve it will draw the antifreeze up rather than pulling water from your storage tank.
2015 Forester 2301 - Chevy
Skip & Deb - Denmark, ME & Delray Beach, FL
Forester Fred is online now   Reply With Quote
Old 08-29-2016, 08:08 AM   #8
Wolverine 1945's Avatar
So does the one hose have an open end some where ???
Wolverine 1945 is online now   Reply With Quote
Old 08-29-2016, 08:22 AM   #9
RedLdr1's Avatar
On most units I've seen the Red and Blue lines going through the floor with valves are the Low Point Drains for the hot and cold water pipe systems. Look and see if those two lines dump out under your motor home. If so they are your drains. The fresh water tank normally has a separate white valve for its drain.
The anti freeze system normally is connected to the water pump with short white hose attached to it. There will be a switch / valve to connected to it to select the fresh water tank or the anti freeze pick up hose.
I've attached a picture of what my MH has to show the color code and what it looks like... The locations vary by model but the colors are fairly standard.
Name:	Outside Storage With Fresh Water Access Panel Open.jpg
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 08-29-2016, 08:38 AM   #10
To me the Black Valve looks to be some sort of Hot Water drain valve,,, I would have to see where the Red hose goes ???
