05-30-2018, 07:45 AM
What Kind of Water Line?
I am wanting to re-position my water pump a bit to make access more convenient. And I need some of the white (high pressure?) water line to accomplish what I want to do. But, I am having trouble finding out what kind of line this is and where to get a couple of feet of it.
Imprinted on the water line is "PRESSURE NSF/ ANSI 61 IAPMO . . ." (see pic at link below). I have learned that NSF 61 indicates that the line meets standards for drinking distribution systems. But that's as far as I have gotten.
Any counsel would be greatly appreciated!
https://drive.google.com/open?id=1u1...gNS-Q4SvGPZgRq
The Happy Hopkins
2014 Sunseeker 3170DS
Travel Companion: Nora "The Anorable"
05-30-2018, 07:49 AM
Would guess it to be white pex
1/2 in. x 25 ft. White PEX Pipe
https://www.homedepot.com/p/202033042
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
05-30-2018, 08:01 AM
Standard 1/2 inch Pex line. Available at any Lowes/Home Depot/Ace Hardware.
When buying, they will almost certainly try to sell you a Pex Tool so you can crimp the ends. However, ask them to show you simple 1/2 inch "Gator" or "Sharkbite" fittings. Work just as well, cheap, and won't leak.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
05-30-2018, 08:51 AM
Alas, not PEX
Alas, this is not PEX. This is much smaller in diameter, is (a bit) flexible, and seems to be nylon-reinforced.
The Happy Hopkins
05-30-2018, 09:25 AM
I recently had a fitting leak at the outdoor shower connection on my trailer. The fitting was some how cross thread so, I needed to replace this hose and the outdoor shower faucet. The plastic threads were damaged on both pieces. I had a dealer make up a new 1/2 PEX ($3.14) hose with fittings to replace the ruined factory hose. PEX hose will work but it tends to be a little stiffer. You need to have a larger bend radius with this hose material and can not be routed with a sharp bend. So, plan accordingly when moving your water pump.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
05-30-2018, 09:34 AM
I think your Google Drive link is private, I can't access it. I'm VERY surprised it's not PEX, the vast majority of RVs are.
05-30-2018, 09:48 AM
Location: Alberta - East of the Rockies, West of the Rest
I can't see the pic but for a project like this I would recommend 100 psi 1/2" braided PVC hose for flexibility and to absorb the vibration from the water pump.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
05-30-2018, 12:44 PM
When I looked at my pump, I recall some of the tubing to be what I would call ”Tygon” tubing; I think manufactured by Nalgene. It is a braided polyethylene (?) tubing rates for higher pressures.
2017 Coachmen Viking 21RD
2015 GMC Sierra SLE 1500 w/Timbrens
5.3L V8 3.42 Gears Reg Cab 8' Bed
Curt Trunnion WD Hitch
Tekonsha P3 Brake Controller
05-30-2018, 12:49 PM
RV parts stores will have what you need including a coupler if needed. There is nothing high pressure in the trailer unless you don't use a water regulator on the city water connection and then it could be anything.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
05-30-2018, 02:35 PM
It's this stuff.
It's this stuff.
Larry
05-30-2018, 02:46 PM
Just looked at my setup. It also is white and looks like what you described. goes from fresh water tank to pump and about a foot of pipe out of pump to cold water pex line. Also used for anti-freeze pickup line. Much more flexible than pex and I am thinking able to absorb vibration from pump motor. It is Valterra 1/2" ID, W01 2105 NSF, cold water only, 150 psi.
I have seen this pipe in RV stores. As for bending pex pipe you can buy a plastic guide that allows pex to bend at a fairly tight angle and keep it in place also can be fastened to framing or whatever.
05-30-2018, 03:20 PM
Bending PEX
Using a heat gun with on PEX (with moderation) works very well. Keep twisting the pipe as you heat it, then bend carefully. This works best if a helper holds the heat gun as you twist the pipe. Continue to heat it as you make the bend. If you go slowly, the pipe won't collapse at all.
I've actually done this with 2" PVC and a Bernz-O-Matic, too, when constructing my last house.
Larry
05-30-2018, 03:30 PM
Many of the big box stores don't carry the white in bulk but you can often get supply lines long enough to make repairs or splices.
Here are some at HD...
1/2" White Supply Lines
05-30-2018, 03:45 PM
See post #21
See Post #21. $10 for 20 feet bulk at Lowes. No fittings on either end.
Larry
05-30-2018, 04:41 PM
Lots of options, most will work some are expensive. As I stated earlier, 1/2" braided PVC hose it commonly used.
Whatever you end up doing, do not connect Pex directly to the pump, it is not flexible enough to absorb the vibration and will eventually shake the connections loose.
Use cinch clamps or slightly widened copper Pex clamps on the fittings, no gear clamps if you can help it!
Ordered: 2021....
05-30-2018, 08:15 PM
You do not necessarily have to use the braided line. You can use PEX which will also allow you to use SHARKBITE type fittings. They have the blue and red PEX at Lowe's in the same section. Have one of the plumbing guys show you how the SharkBite fittings work.
It will almost seem too easy!
I saw a response about PEX not being as flexible as the braided tube. It is true that PEX is more rigid, but it will hold a curve better than the tube will, which means it will not crush as easily. The braiding is imbedded only to help prevent bursting from pressure. It does not prevent collapse from tight curves. You can get curve holders for both types. I would definitely recommend it for any bend beyond 45 degrees.
05-30-2018, 08:57 PM
A few years ago I was in need of a hose that would hold pressure for my toilet in my TT and was in Mackinaw City. Tried a lot of possible places and then came on a marine supply store (Sheplers) and they had just what I needed. It was a hose as you described and was rated at 250 pounds pressure. I could buy it by the foot and they had various diameters available. I would presume you can get this type of hose at other marine stores as well where you live or are camping.
05-30-2018, 09:08 PM
Larry
Yep.. the OP asked for white.
Your link was for clear.
