Old 03-13-2015, 04:44 PM   #1
What's causing this?
First 2 nights in our new 5th wheel. 2nd morning I noticed water leaking and thought city connection was loose. Instead I see water coming out of the fresh tank fill. Apparently when connected to city water some water is being diverted into the fresh tank. It took two nights to fill and start overflowing but don't know the cause. Bringing it to the dealer but first appointment is the 26th. Any ideas or suggestions in the meantime?
clicker1944 is offline   Reply With Quote
Old 03-13-2015, 05:01 PM   #2
Same thing happened to me. My dealer said it was a bad check valve in the water pump & replaced it under warranty. I haven't checked it yet to see if all is well, but will this weekend as we are going camping for about a week. What I did until I got it fixed was just leave my fresh water tank drain valve slightly open & let it drain out.
Papa GLS is offline   Reply With Quote
Old 03-13-2015, 05:19 PM   #3
Not much Info to work with? WAG would be (Check valve in F/W Pump,turn OFF City water and turn ON pump,this might clear the situation? Next (Maybe?) you have a Unit with F/W fill from the C/W Inlet that is turned part way ON? Either way Drain your F/W tank,no need to keep running it on the Ground! Youroo!!
Old 03-13-2015, 05:36 PM   #4
No, it's a manual fill no valve that's slightly turned on, that would be way too easy to fix. Running the pump didn't fix it, again way too easy. Tank no longer full (didn't need to travel with 400lbs of water) just looking for any ideas of what it could be before bringing her in.
Old 03-29-2015, 11:03 PM   #5
What was the result? Mine is going the other way. When I turn on my FW pump it shoots out the city water connection.
seminole191 is offline   Reply With Quote
Old 03-30-2015, 05:01 AM   #6
fonzie's Avatar
Take screen off at city connection and reset check valve by pushing/releasing
Name:	city water inlet Check-valve-seated.jpg
Fonzie
Old 03-30-2015, 10:41 AM   #7
Took it in Last Thursday, they said the pump has a check valve that may have debris in it. They just replaced the water pump since it is not time or cost effective to take the pump apart to clean it. We head out on Wednesday for our first trip since the repair. Will let you know if it's all better.
2017 Grand Design Reflection 367BHS 5th wheel.
2017 F350 crew cab 6.7 4X4 srw.
Old 03-30-2015, 02:51 PM   #8
Take The Road Less Travld
MuddauberE's Avatar
Make sure your screen is properly placed on the city water hookup. there should not have been any debris on it unless there was something in the line from the factory. The dealer likes to get you on the "it was debris from dirty water" or in my case, a spider web in the fuel tubes (even thought it was on their lot not my driveway) and say it's not under warranty.. sorry had to get that off my chest LOL
Enjoy!
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 04-02-2015, 09:45 AM   #9
Well happy to report that replacing the pump seems to have done the trick. Thanks for all your suggestions.
Old 04-26-2015, 10:12 PM   #10
This is happening to my 2013 Sabre TT, Can I just take the pump out and connect the 2 hoses with a nipple ?
jiggerk is offline   Reply With Quote
Old 05-03-2015, 05:37 PM   #11
Hicks43's Avatar
^ yes just run them in a loop
Hicks43 is offline   Reply With Quote
