Old 08-08-2015, 03:12 PM   #1
nomad297's Avatar
What's Wrong With My Water Pump?
My Windjammer 3029W is new. I have been using it on city water for a couple of weeks now, and today I thought I would test out the fresh water tank and pump system. I completely filled the fresh water tank, turned on the pump and went to the kitchen faucet. All I got was a sputtering of water mixed with air. I checked all of my other faucets and got the same thing, except on the hot side, there is a little bit less air and a slight stream of hot water. After I turn things off, the pump will not turn off unless I hit the switch or connect the city water. I also noticed that the pump is pushing a lot of air into my water heater because after I connect the city water and turn on the hot side of a faucet, I can hear water filling into the water heater until it fills up and then sounds normal.
There are no leaks anywhere.
Bruce
nomad297 is online now   Reply With Quote
Old 08-08-2015, 03:48 PM   #2
nomad297's Avatar
I "fixed" it. I took a look at the pump and noticed a diverter valve, obviously for the antifreeze intake on the outside. The diverter was positioned to sucking antifreeze instead of sucking water from the fresh water tank. I flipped the diverter and all is well.
Bruce
pump, water, water pump
