Old 04-19-2014, 09:54 AM   #11
BTW SP 189 owners, the access door is behind the hot water tank and inside under the TV wardrobe on the bottom. Just remove the 4 screws that covers the panel. Screw are located in the corners and remove panel. You can gain access to the water pump and valves and the back of the hot water tank. Really easy when you know where to go.
Tampajohn is offline   Reply With Quote
pump, water, water pump, modifications
