Old 10-17-2018, 05:03 PM   #1
When to open low point drain
Winterizing with antifreeze. Drained the 2 low point drains before pumping antifreeze through lines. Do I open them again AFTER running antifreeze through all the lines or will all the antifreeze run out?
abehmlander is offline   Reply With Quote
Old 10-17-2018, 05:49 PM   #2
Just as confused as you
Scrapper's Avatar
You should drain a little AF out of the low point drains. Any water left in the lines will be pushed to the low points and needs to be drained out.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 10-18-2018, 10:15 AM   #3
I loosened mine just enough to start dripping then a tiny spray from the remaining pressure until I saw pink, then snugged them back up. Because I did not want to drain out the new antifreeze ;(
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
2018 16 days camped, 2019 5 days so far.
Boomerweps is offline   Reply With Quote
drain
