You only use the tank heaters when there is water in the holding tanks, otherwise, with no water in the tanks, there is no need for heat. Nothing in them to freeze.
The tank heaters do not keep the underbelly warm. They are simply heating pads that stick to the tank(s) and apply heat to the tank(s) and their contents through conductivity.
