Old 11-18-2015, 01:53 PM   #11
MNtraveler's Avatar
Hmmm. It should have run pink but if a faucet wasn't opened there could have been an air lock so to speak. Sounds ok as at least there's no pure water sitting in the low point. What do others think?
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-18-2015, 03:45 PM   #12
AquaMan's Avatar
I would open a faucet (hot and cold) and see what comes out. The fact that mostly pink came out is a good sign.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-25-2015, 09:57 AM   #13
Yep, went inside and opened faucets in kitchen and bath, still not much came out. Maybe a couple of dribbles............so other than that AF that is probably sitting in the fresh water tank which I'll drain and flush next spring......I think I'm OK. I took out the anode rod and plug on the water heater and just leave it out until next spring as well.
Salem Lite Hemisphere 232IS
Ford F-250 Super Duty Lariat Crew Cab v-10
jas451 is offline   Reply With Quote
Old 11-26-2015, 08:36 PM   #14
SilhouettePenny's Avatar
Originally Posted by jas451 View Post
OK, what are these? I see two red & blue tubes underneath (really hidden, didn't know they were there) they are capped, no valves to turn. I've already winterized (although
my freshwater tank now has AF in it! - I'll have to flush out next spring!) or so I thought.
I didn't do anything with these last year (because I didn't know that they existed) and everything seemed to work out.
Here is a good product for cleaning the system next spring, however if you can get to the intake side of your water pump next year, you can winterize with only one gallon.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 11-26-2015, 08:46 PM   #15
Ford Idaho's Avatar
OK, Maybe that's where all or some of my AF went. I put about 4 gallons in but the pump
wouldn't pull it out (I might've used 6 gallons last year) so I went with the air method.
My neighbor helped me who used to own an RV park and used to winterize alot of rigs as one of the services that he offered. I was also told that the lines being plastic can/will expand to a point with out breaking, and that it is mainly the fixtures that you want to protect. But I will uncap those lines and see what I get. Thanks for all your help!
I suspect you pumped A/F into your water heater tank or the F/W tank if you used that much to get the job done.
Old 11-26-2015, 08:50 PM   #16
Sorry pic didn't post
drain
