Old 04-13-2016, 10:45 PM   #11
mrpep's Avatar
Doesn't the thread up top look bigger than 1/2"? The one that connected to the gray fitting? Could it be like 5/8 or 3/4"?
mrpep is offline   Reply With Quote
Old 04-13-2016, 10:54 PM   #12
It could be, hard to tell in the photo, just an educated guess from working with 1/2" Pex and knowing that "most" (famous last words ) pipe fittings in my RV are 1/2" FIP and MIP adapters.
But that is why i say take it in with you as a photo may be worth a 1000 words, but the part itself will will speak for itself.
YMMV
I need to
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 04-13-2016, 10:55 PM   #13
mrpep's Avatar
Will do , thanks
Old 04-14-2016, 11:18 AM   #14
There is no way to remove line and slide off, the problem with these crimp clamps, they was all installed before cabinets were set. I worked 1/2 day on one that was down under the vanity probably would have been faster to remove the vanity.
Myrle is offline   Reply With Quote
Old 04-14-2016, 11:24 AM   #15
mike.t's Avatar
Is this something that an Rv shop would have ? Maybe even cut by the foot and add fittings?
You will get a lot more help at the local plumbing store than you will at an Rv shop.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-14-2016, 11:26 AM   #16
mrpep's Avatar
Yeah, it's become a problem for me as well. The real trick is making the length to almost exact . The pex is stiff so I have to place the toilet on the threads and lower all together evenly .
Old 04-14-2016, 11:33 AM   #17
mrpep's Avatar
I just talked to a guy here at work and he tells me to just use that braided rubber hose that you see under a faucet sink. I actually think it will work since these are all standard npt thread sizes
Old 04-14-2016, 11:44 AM   #18
mike.t's Avatar
Ever think of using flex?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 04-14-2016, 12:51 PM   #19
mrpep's Avatar
Here's the plan. I don't see why it wouldn't work, wish me luck.
Old 04-14-2016, 04:54 PM   #20
Yep, that should work.
Dale & Karen
