Old 09-16-2010, 07:22 AM   #21
Infractee
Talking
Originally Posted by Pa-cj5 View Post
Empty both tanks, run garden hose into shower stall, turn on water and go outside to your drain. Pull gray tank, if water comes out your connected into that tank, If not close and pull the blank tank.
I would say that if nothing comes out of the gray then you can skip pulling the black.... (unless you are in a place you can dump some black tank residue or have a sewer line hooked up)
RhoZeta is offline   Reply With Quote
Old 09-16-2010, 04:00 PM   #22
MikeInColo's Avatar
I have two grays and one black tank. The gray tank that is called the Galley is directly under the shower and collects the shower water (and nothing else). The other gray tank collects both sinks (bathroom and kitchen). However, the galley gray tank runs through the black to drain. I like it in that it serves to flush out the black after draining.
MikeInColo is offline   Reply With Quote
