Old 03-03-2013, 04:15 PM   #1
Where is fresh water drain for Sandpiper?
Hey everybody. I'm new here and already have a question. I have a 2008 forest river 305rgs sandpiper and can't locate my low point fresh water drain.
Horns07 is offline   Reply With Quote
Old 03-03-2013, 04:19 PM   #2
TURBS's Avatar
Sometimes the fresh water drain barely sticks below underbelly .
Sometimes the valve is underneath some times its inside the camper.
Your fw drain should be directly below fw tank.
Now your "low point" drains would be different than fw tank drain.
Welcome to the forum.
Turbs
Old 03-03-2013, 04:23 PM   #3
TURBS's Avatar
Fw drain
System low point drains
Old 03-03-2013, 04:47 PM   #4
Originally Posted by f1100turbo View Post
Fw drain
Attachment 25025
Attachment 25026
Now I have those two pex lines. If I'm thinking right those just drain the lines. But I still can't find anything for my fw tank.
Old 03-03-2013, 04:56 PM   #5
TURBS's Avatar
Take a better look... it sometimes can be hard to find and barely sticking through the underbelly.
Sometimes you'll have a shut off valve like mine and sometimes the valve will be inside camper.
I'll post anther picture of an older drain valve.
Turbs
Old 03-03-2013, 04:57 PM   #6
TURBS's Avatar
Old 03-03-2013, 04:59 PM   #7
I went back and looked and still couldn't find anything.
Old 03-03-2013, 05:06 PM   #8
TURBS's Avatar
Hmmmm well hopefully someone with a similar or same model and year will be able to help.
Can you take a good pic underneath where your fw tank is located?
Turbs
Old 03-03-2013, 05:16 PM   #9
I don't know where exactly my fw tank is the whole underneath is insulated
Old 03-03-2013, 05:20 PM   #10
bikendan's Avatar
my '07 Roo's FW tank is in an inside cabinet, with the drain valve right next to it.
find your FW tank and look for a valve that can be pulled up or turned to drain.
there is no "low point" drain for the FW tank, just a regular drain.
low point drains are for the water lines.
Old 03-03-2013, 05:26 PM   #11
TURBS's Avatar
Your fresh water tank is generally right underneath where you fill it.
Old 03-03-2013, 05:31 PM   #12
Herk7769's Avatar
Mine is tucked under a slide and fastened to the frame.
REALLY a PITA to get to. Gonna move that some day...
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 03-03-2013, 05:39 PM   #13
B47
My 2012 Silverback FW drain is behind the most rear axle on the drivers side.
Old 03-03-2013, 05:50 PM   #14
TURBS's Avatar
Yes I forgot my flagstaff had it tucked under the slide as well.
It had the drain like The last pic I posted.
Old 03-03-2013, 05:58 PM   #15
B47
Well to be exactly correct, mine is also under the slide, but no problem getting to it when the slide is retracted.
