Old 04-16-2016, 12:00 PM   #1
Where is my water filter??? (390qsmb)
Ok, I must be missing it somewhere. Picked up our new Chapparal 390qsmb yesterday. Was told there was a water filter housing already installed behind a panel in my basement (basically directly behind the water control station). Took the panel off today. No filter to be seen. Does anyone know where it is or suppose to be???? Kind of looks like it should go here....Click image for larger version
Name:	ImageUploadedByForest River Forums1460826027.321795.jpg
Yes??? No???
Thanks!
lordj37 is offline   Reply With Quote
Old 09-15-2016, 09:36 PM   #2
Did you ever figure this out? I don't believe ours has a water filter, but curious if there is one hidden somewhere...
2017 Coachmen Chaparral 390QSMB
2008 Ford F-450 Lariat 4X4 CC LB DRW PSD
http://www.roadschoolnotoldschool.com
http://www.roadbrewing.com
TheRowlands is offline   Reply With Quote
Old 09-15-2016, 10:10 PM   #3
I took our 390 back in for some warranty work and added the missing water filter to the list of things to check on. When I picked it up, the dealership told me they checked on it but found out this unit doesn't come with one. I didn't push any further.
Old 09-15-2016, 10:44 PM   #4
You're better off without one internally installed. Many of us have bypassed the internal filters due to cracking and leaking concerns.
Use an external one.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 09-16-2016, 05:29 AM   #5
Good point. 👍
Old 09-16-2016, 06:29 AM   #6
Originally Posted by lordj37 View Post
Ok, I must be missing it somewhere. Picked up our new Chapparal 390qsmb yesterday. Was told there was a water filter housing already installed behind a panel in my basement (basically directly behind the water control station). Took the panel off today. No filter to be seen. Does anyone know where it is or suppose to be???? Kind of looks like it should go here....Attachment 105093
Yes??? No???
Thanks!
It appears as though you could install a whole house filter in place of that horizontal blue pipe in your picture, but your probably better off using an external one as "rockfordroo" suggested.
The campco external filter with flex hose is under $16 at Walmart and replacement cartridges are about $18 a pair.
https://www.walmart.com/ip/Camco-Wat...-Hose/14504321
When using city water hook it up at the trailer inlet. when filling a fresh water tank, hook it up at the end of your hose just prior to filling your tank.
ShermanD is offline   Reply With Quote
Old 09-16-2016, 08:49 AM   #7
Yep, that's exactly what we did this summer. Worked out fine. Thanks!
Old 09-16-2016, 09:29 AM   #8
AquaMan's Avatar
The external filter is nice for those who have their filters installed inside under a cabinet or such, but if you have an outside wet/control station, any leaks or such will just drain out. I personally have never had one leak, crack, or unscrew by itself.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 10-20-2016, 10:25 AM   #9
MNtraveler's Avatar
See the photo I just posted in this thread:
Water filter:bypass or remove?
Also I just read several other threads where people had clogged faucets and/or toilets due to sand, gravel etc.
Don't take the filter question too lightly.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 32; RV to date: 35
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
water, water filter
