Old 09-17-2010, 07:39 PM   #1
Where is my water pump?
I'm still trying to figure out the new trailer and was wondering if someone could clue me in on where they hide the water pump. It's an 04 32RLSS.
2004 Sandpiper 32RLSS
1999 F350
Grounded is offline   Reply With Quote
Old 09-17-2010, 08:26 PM   #2
milzat's Avatar
Being it's an RLSS, I'd have to guess it's in or near the right front storage compartment.
Of course, I've been know to be wrong more than once.
milzat is offline   Reply With Quote
Old 09-17-2010, 08:32 PM   #3
Turn it on and then try to zero in on its location. Check outside for the fresh water tank filler location. The pump should be near your fresh water tank. It may not be easy to find and you may have to remove a panel to get to it.
Hokiehall is offline   Reply With Quote
Old 09-17-2010, 11:47 PM   #4
waterpump local
Hey Grounded, on my Wildcat 29bhph, my pump is about as far from the fresh water filler as can be. My pump is in the front compartment, next to the hydraulic pump for the front landing gear and slide-out.
dieseldad55 is offline   Reply With Quote
Old 09-17-2010, 11:56 PM   #5
We have a Flagstaff 831RLSS which is probably the same as yours. It is in the bottom left panel under the entertainment center, (TV). You have to take the panel off. Note that there is a 7.5 automotive type fuse close to it. Get some spare fuses! The in house water filter should be there too.
Hope that helps.
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 09-18-2010, 08:31 AM   #6
After looking at a diagram of your interior, which is different from mine, I would say look in the panel to the rear of the shower, mine is under the shower stall.
Let us know where you find it.
Old 09-19-2010, 10:18 AM   #7
Hope that helps.
We have a winner! Thanks.
1999 F350
